Bad news....
Old May 15, 2007 | 08:34 PM
  #21
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Bad news....
ORIGINAL: ponyx2
Sound advice from all. For what it's worth I would yank it out and rebuild it....but I do in fact have a "sneaky pete" referred to earlier. They are a life saver doing warranty work at a dealership.
Exactly how does this sneaky petething work? Is it the rope trick?
Old May 16, 2007 | 11:01 AM
  #22
PReal's Avatar
PReal
I think I'm going to go ahead and try the mustangsteve way and not remove the engine for now. I only wish this started leaking a year from now whenthe money is availablefor body and engine work.
Old May 16, 2007 | 01:16 PM
  #23
Norm Peterson's Avatar
Norm Peterson
Inspect the crank where the seal rubs. If it has a groove that you can feel, even a new seal may not be able to develop enough contact pressure to keep the oil inside. There may be a thin repair sleeve that you can install to restore the crank sealing surface.
Glen - the "sneaky Pete" tool is still available (Lisle). Link with pic.
Norm
Old May 16, 2007 | 01:31 PM
  #24
PReal's Avatar
PReal
That sneaky pete is basically a tool that does the mechanism mustang steve recommends. Interesting.
Old May 16, 2007 | 01:38 PM
  #25
Soaring's Avatar
Soaring
I ♥ Acer
If that sneaky pete thing works, that will same you a ton of money and time.
Old May 16, 2007 | 02:21 PM
  #26
JMD's Avatar
JMD
ORIGINAL: PReal
Does your car still have the stock 289? The reason I ask is that if you have a later engine, the engine may not use the "rope seal" at all, it could use the rubber seal.
Just somthing to keep in mind.
Old May 16, 2007 | 07:56 PM
  #27
ponyx2's Avatar
ponyx2
A sneaky pete is basically a corkscrew made of wire that is flexible. You "screw" it into the main seal and yank it out.
Old May 16, 2007 | 11:45 PM
  #28
Wayne67vert's Avatar
Wayne67vert
Way back in 1966, I had a '59 Ford Fairlane with a leaky rear seal. The mechanic used the "Sneaky Pete" to replace it. I watched him and it didn't seem too difficult. It is also used to install the new seal.
Old May 17, 2007 | 12:16 AM
  #29
mustube's Avatar
mustube
ORIGINAL: valley firearms
There used to be a tool called a sneaky pete. It allows you to replace the seal by just pulling the rear main cap. I have not heard of one in 23 years though. Call around and see if there is a way to replace it by just pulling the main cap.
[align=left][/align]
i used one of those on my rebuild last year, not that hard to use just hard to hook the seal and pull it around the crank, only took a few trys
Dathan
Oct 5, 2015 05:52 AM
KingRando
Oct 2, 2015 08:06 AM
ChampInSD
Oct 2, 2015 04:55 AM
UrS4
Sep 30, 2015 10:13 AM
GLOCKer
Sep 28, 2015 07:36 AM
