Fan Shroud Bracket Question
Old May 15, 2007 | 03:23 PM
68pony5's Avatar
68pony5
Default Fan Shroud Bracket Question
I have a 1968 Coupe with a 289 2v. I have a 3 row radiator with new water pump.. I upgraded it froma 2 row but still have the stock 4 blade fan. Of course, in traffic it runs warm then goes to normal temp range when moving. I have no AC but I do have power steering. I am going to buy a fan shroud and a 6 blade fan to upgrade cooling system. What type of backets/hardware do I need? The NPD, DMP books I have list the brackets for only 65-66 mustang. Will a 3 row 1965-66 brackets work for a 1968 3 row shroud setup.
Thanks,
68Pony5
Old May 15, 2007 | 03:54 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Fan Shroud Bracket Question
The fan shroud that I got from Texas Mustang had the mounting brackets (hardware) in the box with the shroud. If you are ordering it from NPD, give them a call and ask.
Old May 15, 2007 | 05:24 PM
66GTKFB's Avatar
66GTKFB
I had to bend my 'three row' brackest to fit my 'three row' radiator and shroud. The reason is thatall three row radiators are different. Get the brackets and don't be surprised if you have todo a little bending.
Jim
Old May 15, 2007 | 05:43 PM
gothand's Avatar
gothand
I just installed a shroud this past weekend on my 4-row radiator in my '65. I got the shroud and brackets from NPD. I don't know about them working on a '65, but like Jim said, I too had to bend them a bit to get the shroud to line up properly. It also tooka bit of trial fitting to make sure I had the brackets lined up correctly.
Oct 7, 2015 07:02 PM
Seanam
Oct 4, 2015 10:15 AM
Sep 17, 2015 07:57 PM
jaiidutch
Sep 14, 2015 10:29 AM
