ITS THERE!!
Old May 16, 2007 | 03:58 PM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
Default ITS THERE!!
my 67 stang thats been giving me all the problems is finally finished, but then i ran into a problem overheating! Dorve the car unleashed the 331 beast from hell and I just watched the temperature gauge rising with speedo, so i threw down 150 for an aluminum finned 3 copper core radiator an electric fan and a shroud.
Do you guys think that will stop my overheating? Or do i need something else?
Old May 16, 2007 | 04:02 PM
gothand's Avatar
gothand
Default RE: ITS THERE!!
ORIGINAL: USMCrebel
It depends on what was causing the overheating in the first place. If it is because of your timing, faulty/incorrectly installed thermostat, etc., then no. Hopefully the mods you are doing will take care of it. If not, you may want to look into these othere things.
Good luck!
Old May 16, 2007 | 04:05 PM
USMCrebel's Avatar
USMCrebel
Im pretty sure thats its b/c im trying to cool a 331 with an I6 radiator.
Old May 16, 2007 | 04:08 PM
dr1965's Avatar
dr1965
ORIGINAL: USMCrebel
Thats like tring to put out a fire, with a Ice cube.
Old May 16, 2007 | 04:36 PM
USMCrebel's Avatar
USMCrebel
dr1965
I like that, and yeah it worked great until i cranked it and put it in gear.
Old May 16, 2007 | 05:00 PM
andrewmp6's Avatar
andrewmp6
yeah a inline 6 radaitor isnt helping you make sure you have a over flow and the right radaitor cap should be fine
Old May 16, 2007 | 05:05 PM
Soaring's Avatar
Soaring
I ♥ Acer
Put some water wetter in that new rad. Here is a demonstration that is pretty interesting..
http://www.redlineoil.com/products_c...ubCategoryID=4
Old May 16, 2007 | 05:11 PM
andrewmp6's Avatar
andrewmp6
soaring is right i put water wetter in my truck since the 1ton chevy 454 are great at overheating but since the water wetter it hasnt yet
USMCrebel's Avatar
USMCrebel
That was helpful, i just got another call telling me that to fix a tranny leak is $150. so im out 300 in 2 days...that blows
Old May 17, 2007 | 01:23 AM
superdavid's Avatar
superdavid
ORIGINAL: USMCrebel
All that for $150???? Am I reading that right? Where? I'm having heating problems too...
