'65 vert windshield header trim
Old May 16, 2007 | 09:22 PM
6marc5's Avatar
6marc5
Default '65 vert windshield header trim
Hello,I'm trying to remove all the trim around the windshield of my '65 convertible. The main piece on the top is very wide. Is there a special tool for this,or the same tool for the rest of the windshield trim? any help will be much appreciated! Thanks,marc
Old May 16, 2007 | 10:19 PM
noroof66's Avatar
noroof66
Default RE: '65 vert windshield header trim
Just went out and looked. I see what you mean, no idea... LuckilyI have never had to pull that piece.
Old May 16, 2007 | 10:28 PM
6marc5's Avatar
6marc5
Yep,thats the one. The bottom of it has screws. Thought it would just pull off ,but nope. Must have some serious glue up there lol. I guess I'll just take a putty knife and try to gently remove it.
Old May 17, 2007 | 01:08 AM
66GTKFB's Avatar
66GTKFB
Ok rag-toppers, there are two studs on each side that hold down those mouldings accessed from the inside. You need to take off the rear view mirror,visors and the inside moulding, held on by four phillips head screws, to get there. The nuts require a 3/8 deepwall hex socket. Access is threw a square hole in the frame. Don't forget. there are two screws holding that outside moulding on as well. Go for it.
Jim
Old May 17, 2007 | 05:44 PM
6marc5's Avatar
6marc5
DUH! how didI not see the holes in the frame. Thanks for the help Jim,much appreciated!
Old May 17, 2007 | 05:51 PM
66GTKFB's Avatar
66GTKFB
When I read about the putty knife prying technique, I cringed. Way back when, I used a similar device and the same basic technique on a piece of aircraft equipment - I destroyed it while trying to takeit apart. It was fun. The education that I received from my father has stayed with me (a leather strap in the shed reinforced it), find out how it was put together before you take it apart.
Jim
Old May 17, 2007 | 06:01 PM
6marc5's Avatar
6marc5
I'm gladI read this before,I wouldhave damaged the trim and would def have kicked my own a$$.
thanks again!
GimpyHSHS
19
Dec 19, 2023 01:12 PM
b8checker
Oct 8, 2015 12:55 PM
mdg
Oct 1, 2015 07:04 AM
b8checker
Sep 30, 2015 07:11 AM
junior04
Sep 28, 2015 10:53 AM
