top loader and low gears
Old May 18, 2007 | 04:40 AM
valley firearms's Avatar
valley firearms
Default top loader and low gears
Well now that I have everything, I will start to piece things together. At present I have 411 gears in my 9". With my C4 3 speed automatic it really tachs out to where I hate taking it on long drives. I'm wondering if there will be a difference with the toploader. Is the 4th gear 1:1? Would it be the same as my 3rd gear in the C4?
[align=left] [/align]
Old May 18, 2007 | 07:32 AM
andrewmp6's Avatar
andrewmp6
Default RE: top loader and low gears
im not sure on the toploader but the t5 is do you want a stick or auto if a auto get a aod or there is a overdrive kit you can put on a c4
Old May 18, 2007 | 11:32 AM
Decurion's Avatar
Decurion
It might drop a couple hundred rpm on the high side since youre eliminating the slip of the torque converter, but basically engine rpm will be the same. Both transs have a 1:1 top gear. Unless you already have everything to go with a manual, its probly easier to either put in some 3.50 cogs, or go with an AOD.
Old May 18, 2007 | 11:57 AM
highhilleer's Avatar
highhilleer
ORIGINAL: andrewmp6
You speak of the gear vendors unit http://www.gearvendors.com/hrford3s.html
Good piece but for the price, you could swap in an AOD transmission AND new rear gears.
Old May 18, 2007 | 12:16 PM
Soaring's Avatar
Soaring
I ♥ Acer
4th gear on the toploader is 1:1 just like 3rd gear. Either a 5 speed or an AOD is the only way you are going to drop the RPMs. You now have a go quick car for around town, but you will need to take a wheel barrow full of money to buy gas if you take a long trip.
Old May 18, 2007 | 01:10 PM
Smothers's Avatar
Smothers
ORIGINAL: Soaring
Not to mention the extra wear on the engine. I'm turning about 3,500rpm @ 65mph with my toploader and 3:50 gears. I'm gonna switch them out for 3:25 sooner then later.
Old May 18, 2007 | 10:22 PM
67mustang302's Avatar
67mustang302
Get a TKO 500 or 600, or somehigher gears. You really don't need 4.11's unless you have an engine that goes to 7k rpm, otherwise you pull out of your powerband quickly and end up in a higher transmission gear that's reducing power to the wheels. You'd be suprised how fast you can go with even a 3.00 or a 3.25 gear and the right setup. Gears like anything else have to match the combo you have. 4.11's with a stock cam or 2.79's with a drag race cam don't make much sense
musnicki
Sep 23, 2015 07:11 AM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
dalefrancis88
Sep 11, 2015 07:15 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
