Looking into buying a stang.
Old May 19, 2007 | 01:39 AM
TangFool's Avatar
TangFool
Default Looking into buying a stang.
Going to look at a 1970 coupe this weekend. This is what I have been told:
32k original miles
Rust on passenger side quarter panel, drivers floor bood and hood
302
stoped running in 94-95ish when they purchased
So I think it is a F-code i am going to get the vin hopefully sat, and look at the car sunday.
Other then bondo and rust, anything I should look for? They want 2200 for this thing, and they sound firm.
Any help would rock, I am hopefully going to turn this thing into a street machine, I have a total budget of about 12k right now, and can hopefully do all engine work myself.
Thanks in advance~!
Old May 19, 2007 | 01:42 AM
atomsk680's Avatar
atomsk680
Default RE: Looking into buying a stang.
ORIGINAL: TangFool
32k original miles
302
Thanks in advance~!
rust is the major concern to look at, check floorpans, frame rails, bring a magnet and run it around the body to see where the bad areas are
Old May 19, 2007 | 01:44 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
2200 is really steep for a non running 69-70 coupe being thats it has low miles adds a little but id think make 1200-1500$
Old May 19, 2007 | 01:52 AM
TangFool's Avatar
TangFool
yeah i was going to bring a magnet and a maglite, body seems straight and really no dents from the pictures. Hopefully the frame is good it has been kept in a heated storage unit since 94-95 when it stopped running.
Old May 19, 2007 | 02:03 AM
atomsk680's Avatar
atomsk680
if all checks out good offern him 1800 for it cause it will cost some $$$ to tow it
Old May 19, 2007 | 02:08 AM
TangFool's Avatar
TangFool
I have a trailer, and a 1997 F250 powerstroke, maybe i should show up with my other car, and be like, well its got rust here and here does not run, and I will have to pay a guy with a trailer to come and get it.
Old May 19, 2007 | 02:09 AM
TangFool's Avatar
TangFool
So what are the areas that if it has rust holes other then the frame, should I just forget the whole project?
Old May 19, 2007 | 02:15 AM
atomsk680's Avatar
atomsk680
the cowl vent, itsa PITA to swithc it wiht a new one, BUT starting in 69 they came with removable top for easy access to the cowl, check out my cardomain if you want to see some areas that normally rust, im about to updte within the hour
Old May 19, 2007 | 02:16 AM
valley firearms's Avatar
valley firearms
Sounds steep to me too. If you have 12K you can find something w/o any rust. You should be able to find a sportsroof for under 12K also.
[align=left] [/align]
Old May 19, 2007 | 03:00 AM
atomsk680's Avatar
atomsk680
ORIGINAL: valley firearms
[align=left][/align]
thats true, you can either try and pick up this coupe for cheap, then you got a good amount of $$$ to fix it how you like, or you can try and find an already done coupe or rustfree fastback or sportsroof
