what would you put in your '65
Old May 19, 2007 | 05:20 AM
  #21
superdavid's Avatar
superdavid
Default RE: what would you put in your '65
My 408's a daily driver... drove it out here to Cali from Texas.
Old May 19, 2007 | 05:31 AM
  #22
ShAkE N BaKe!!'s Avatar
ShAkE N BaKe!!
ORIGINAL: 67mustang302
ORIGINAL: ShAkE N BaKe!!
Yup, not many were produced, and it was originally developed by Ford to be an awsome high performance engine, but it came out right before the gas crisis/oil embargos of the early 70's when American muscle fell rapidly out of favor. The end result, was there wasn't any factory momentum behind it to truely develop it to it's full potential. Now all the support that exists for it is somewhat limited, and as such, pricey. But man, you put some decent parts into a Cleveland even with stock heads and boy does it come alive. That's the nice thing about the CHI heads, combines the best of the Cleveland family(the heads) with the aftermarket/factory support of the 351w.
does this go for all years?
Pretty much, factory there are 2v and 4v heads, the 4v heads have bigger ports, and the valves might be bigger as well. 2v heads are great for street, and 4v heads are great for wild street and race. It's the only head Ford ever produced in years past that was worth a crap without having to "massage" it.
so, just incase i do go check out a C. what should i look for on the heads, if their 4v what should it say?
Old May 19, 2007 | 06:07 AM
  #23
latamud's Avatar
latamud
I vote 351C because 1 for 1 vs a 351w you will be better off. Dodgestang and Opentracker have 351C based engines in their 65s without cutting the shock towers. I have a 408W with 2v C heads and did have to notch the shock towers quite a bit. I think the wow factor with a 351C is greater than with a 351w.
Old May 19, 2007 | 06:53 AM
  #24
2bav8's Avatar
2bav8
Neither...
A 347 stroker.
Its lighter, smaller and makes more than enough power for my on-track applications.
Old May 19, 2007 | 07:20 AM
  #25
andrewmp6's Avatar
andrewmp6
shake the 351c was made for less years and cant be stroked as far as a 351w and the 351w was in the f150 tell 97 thats why they are cheaper more of them around.can do the best of both worlds 351w block 351c heads
Old May 19, 2007 | 12:50 PM
  #26
Soaring's Avatar
Soaring
I ♥ Acer
I'd put a 289 in it because that's what it came with.
Old May 19, 2007 | 01:11 PM
  #27
Mykkus's Avatar
Mykkus
Windsor. Little more 'wolf in sheeps clothing' though the C would be interesting.
But personally I'd probably run a 289/302 myself. Plenty streetable, light, not too miserable on gas if you
build it correctly...I just like em.
Old May 19, 2007 | 02:15 PM
  #28
67mustang302's Avatar
67mustang302
Do like me, build a healthy 302 with lightweight guts and spray it
Old May 19, 2007 | 02:35 PM
  #29
JMD's Avatar
JMD
and why?...
I voted Windsor, because recently I put a W in a 66 engine compartment, and it is a tight fit. I had to "modify" the swap headers a little to get them to fit. As far as I am concerned, a 351 W fills the engine compartment just fine.
That said, I do believe that the "C" motor was a better, stronger, and more efficient design than the W, (I am a big fan of canted valves, and 4 bolt blocks).
As for those folks who have decided to go the extra mile byshoehorning the "C"engines into early Mustangs, I offer much respect,, like wow, good job!
351 W. is a tight fit, One extra inch of deck height does not sound like much, but it makes a huge difference.
[IMG]local://upfiles/59032/729E1C08D14646199FC4EA81526DC2D3.jpg[/IMG]
Old May 19, 2007 | 03:16 PM
  #30
hellion_79's Avatar
hellion_79
a cleveland, that would be if I wasnt on a budget
