adapter bushing
Old May 20, 2007 | 12:03 PM
mortman's Avatar
mortman
Default adapter bushing
Been installing power braking system but came accost one problem I can’t seem to find an adapter bushing that will go from 7/16 to 3/16. The adapter is needed to attach the rear brake lines to the distribution block. Had to cut all the brake lines, now need to put on new nuts and re flair the lines, I am in Sacramento and have turned the town upside down, any clues where I might find the adapter bushing. The one in the pic is from a new master cylinder, I have contacted the vender where I purchased it to see if they have one but no response as of yet. Thanks for any help.
Old May 20, 2007 | 12:17 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
Default RE: adapter bushing
autozone,advanced napa etc carry stuff like that but its usually in the back in storage box but just bring the piece your trying to connect to make sure a correct match is made
Old May 20, 2007 | 04:50 PM
Wayne67vert's Avatar
Wayne67vert
I had the same problem with my '67. I changed from manual to power. The line fittings are not the same. This prevents installing a powerm/c into a non-power car. I bought 2 different premade lines with connectors, cut off the wrong ones, put on the correct ones, flared the lines and then put them on the car. I had to take both m/c and the proportioning valve with me to the autoparts store to figure which lines to buy.
Old May 20, 2007 | 07:02 PM
Soaring's Avatar
Soaring
I ♥ Acer
I get stuff like that at Ace hardware.
Old May 20, 2007 | 07:40 PM
6marc5's Avatar
6marc5
Is there a Lowes nearby? They have tons of fittings.
mtgldr
Feb 3, 2024 09:00 PM
Boostaddict
2.3L Eco-Boost Tech
Nov 24, 2015 06:11 AM
Explosive
Oct 2, 2015 07:45 AM
UrS4
Sep 30, 2015 10:13 AM
Ford_Dude
Sep 15, 2015 03:25 PM
