Setting my Dwell?????
Old May 24, 2007 | 09:46 PM
amanda11270's Avatar
amanda11270
Default Setting my Dwell?????
Hey guys, im attempting to set my dwell, never used a dwell meter before, am I doing something wrong or are my points shot? I have one lead going to the negative of the coil as the instructions say, and one goin to the ground as the instructions say, with the engine running, I have only 4 degrees with my dual point distributor. Do I need to disconnect one set, cause I tried that and still the most I can get is 4 degrees or 0 degrees the other way. Do I have to disconnect the coil wire or something to make this read right? The tach on my dwell meter works so I think it is hooked up right, but still im not sure as i cannot get a even close to the 28 degrees I believe it is supposed to be, is that right 28 degrees for a dual point distributor? Thanks for any input, cause im lost here at present, Ive set timing in the past, but this is my first car that has ever had points.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
TCStangerv6
Oct 11, 2015 05:57 PM
mustangheaven
Oct 7, 2015 10:23 AM
guitarman376
Sep 30, 2015 05:54 PM
UrS4
Sep 30, 2015 10:13 AM
