Think it cant be done?
Old May 25, 2007 | 01:23 AM
restomod@16's Avatar
restomod@16
Default Think it cant be done?
Fitting a Din-styled modern radio into a 67 Radio Bezel isnt possible unless you hog out the center. Many people believe that its hard and time consuming. I did this in 15 minutes and with minimal tools. If you have done the same thing lets see it! BTW this pic was taken with a cell phone, sorry for the crappy resolution. New pics will be here soon.
Old May 25, 2007 | 01:35 AM
4reboy's Avatar
4reboy
Default RE: Think it cant be done?
So wat did you do? explain your process. Did you still have to chop up the dash or no? From that pic it looks like its a peice hanging below the dash but I can't be sure
looks good tho
Old May 25, 2007 | 01:43 AM
farkedup's Avatar
farkedup
You can buy kits for it but its kind of expensive OR you can just carefully dremel it out.....
Old May 25, 2007 | 01:44 AM
farkedup's Avatar
farkedup
Also here's what mine looks like: http://www.networktechs.com/mustang/dscn1352.jpgjust a tape deck in mine... I haven't bothered installing a CD deck... I like the radio!
Old May 25, 2007 | 02:35 AM
67Sally's Avatar
67Sally
Eh, I'm lazy. I just bought a pre-fit bezel. Don't know why I didn't put my face plat in that picture. Should be installed by the end of June
Old May 25, 2007 | 03:41 AM
atomsk680's Avatar
atomsk680
pssh, aftermarket black plastic stock radio bezel for 69/70, $34
DIN black plastic ready for new CD player for 69/70, $340
im taking my chances with a replacement and a dremel
Old May 25, 2007 | 03:44 AM
restomod@16
All i did was use a dremel to cut it out... and shaped to the DIN box.
Old May 25, 2007 | 03:49 AM
atomsk680's Avatar
atomsk680
ORIGINAL: restomod@16
exactly, no need to spend a couple hundred bucks on something you can make in 15 minutes
Old May 25, 2007 | 03:58 AM
connor90's Avatar
connor90
ive done that before...but i was cutting metal on my old dodge truck so it took a bit longer than 15 min. its still pretty easy to do though.
