Bullitt Rims
Old May 25, 2007 | 05:12 AM
67_Mustang's Avatar
67_Mustang
Default Bullitt Rims
Willbullitt rims off a 2005 mustang fit ona 67 coupe? Do they have the same bolt pattern? And does nyone have any pictures of pictures of classic mustangs with bullitt rims on them.
Thanks
Old May 25, 2007 | 08:08 AM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Bullitt Rims
The backspacing is way too deep to fit on a classic chassis.
Old May 25, 2007 | 09:31 AM
remicks's Avatar
remicks
Yeah Soaring is right, I thought of doing the same thing because you can get a set for dirt cheap right now. After doing alot of research they will fit on your car but only after almost 2 inches of spacers which will cause all sorts of problems. The average backspacing run on the classics is about 4.5" but the backspacing on the new 05+ wheels its 5.795, or something close to that I don't quite remember, but way too much to be worth it. It will be cheaper buying the american racing wheels instead of buying the spacers and a neg wedge kit and everything else needed for the 05 wheels.
And yes the bolt pattern is the same for 5 lug mustangs.
Old May 25, 2007 | 10:40 AM
KTM's Avatar
KTM
Spend few Dollars more and get nice set of wheels with correct back spacing in to your car. I did choose set Vintage Wheel Works V45 wheels 17x7.
Old May 25, 2007 | 01:31 PM
farkedup's Avatar
farkedup
I've got 04 bullitt rims on mine the backspacing on the older rims aren't quite as bad but still a bit further than most people will like.
Old May 25, 2007 | 02:55 PM
maverick75's Avatar
maverick75
texasmustang.com
has them with the correct backspace
Old May 25, 2007 | 06:16 PM
gothand's Avatar
gothand
According to this month's Mustang Monthly article, Mustang Steve runs Bullits (not sure which year) with a small spacer (5/8"?) in the rear. For the fronts, I think he had them narrowed 1" and runs them without a spacer. If you can get cheap take-offs, I think this swap would pencil. If your starting price isn't low, however, you'll likely lose out after spending the $300 or so to have the front wheels narrowed.
Good luck!
Old May 25, 2007 | 06:51 PM
JJ68Mustang's Avatar
JJ68Mustang
ORIGINAL: maverick75
texasmustang.com
nice
Old May 25, 2007 | 08:18 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: gothand
Good luck!
I never though about narrowing the Bullits. Yeah, if you can pick up a set at the junk yard for a fair nickel and have them narrowed so you don't have to use spacers, that would look bitchin'. I sometimes wonder how my 03 Mach wheels would look like on my 65.
Old May 26, 2007 | 09:15 AM
andrewmp6's Avatar
andrewmp6
soaring throw the spare tire on the 03 and put the wheel on your 65 just to see what it looks like
