New Member needs help!!
Old May 27, 2007 | 09:30 PM
clemmerj's Avatar
clemmerj
Default New Member needs help!!
Hello everyone, I just got a 67 coupe in need of some real help. I need to replace, (deep breath in) floorpans, both shock tower/apron assembly's, fire wall, front frame rails, front torque boxes, rocker panels,cowl, passenger door skin and rear quarters. Not going to be fun, but in what order should I do them as to not risk causing the body to twist up?
Thanks!
Jesse
Old May 27, 2007 | 09:42 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: New Member needs help!!
As much as I hate to say this Jesse, there comes a time when the life of a car is over. By your description, yours has reached that time.
Old May 27, 2007 | 11:57 PM
green_blurr's Avatar
green_blurr
I think Soaring is afraid to get in a committed relationship with a car is allIf you have the time and willpower anything is possible that is what i have learned by the way you may need a junker parts car. You will need a good mig welder and some time and money
Old May 28, 2007 | 12:02 AM
dnswwood's Avatar
dnswwood
Might want to look for another body and use your car for a donor for engine tranny and so forth
Jeff
Old May 28, 2007 | 12:05 AM
66GTKFB's Avatar
66GTKFB
In this case, Glen is correct. The solution is to find a donor car in better shape than your current project carand then ask yourself the question - which is the better one to start on?
Jim
Old May 28, 2007 | 12:13 AM
LCC's Avatar
LCC
Ah, mine was that bad. It will be a good learning experience. Just take your time, If you don't have the time or patience then look for a better car....
Old May 28, 2007 | 12:27 AM
Celtic37's Avatar
Celtic37
I say go for it, I'd agree with the new body. The one you got would obviously be a parts car.
Old May 28, 2007 | 12:30 AM
Celtic37's Avatar
Celtic37
Then again, look at LCC'sI saw some pics of his at first, and as cool as it was, it wasn't pretty. Now look at it, it's a beauty
Old May 28, 2007 | 06:05 AM
andrewmp6's Avatar
andrewmp6
anything can be fixed depends on money if you can weld and take the time to do it right
Old May 28, 2007 | 03:21 PM
JMD's Avatar
JMD
I would recomend finding an I-6 car with a good and relativly rust free body, and using the parts from your V-8 to make a killer car!
