what to do first?
Old May 28, 2007 | 02:30 AM
mustanglover66's Avatar
mustanglover66
Default what to do first?
I am replacing the complete floor, but should i do it before I put the car on a rotessatire or while its on it. I don't want the car ito get screwed up. Thanks for the help. By the way if anyone needs plans for a rotessatire just email me I got them from ebay and have no problem with sharing.
Old May 28, 2007 | 02:55 AM
Aussie66Fastback's Avatar
Aussie66Fastback
Default RE: what to do first?
why wouldnt you do it on the rotisserie?
the car will be clear of all parts in the way including brake lines, drive shafts and everthing else off the firewall - easier to get at i think
Old May 28, 2007 | 03:25 AM
mustanglover66
Yes it would be easier on the rotisserie, but my concern is removing the bigest strutual part of the car and stressing it in ways that may basicly fold the car. And yes I will brace the door openings.
Old May 28, 2007 | 03:32 AM
Aussie66Fastback
point taken
i have seen cars on rotisserie for rust removal and painting, but couldnt comment directly on floor replacement.
Thumpin 455 would know but he hasnt been on theboards for a few months
Old May 28, 2007 | 03:41 AM
mustanglover66
Thanks for replying even if only to conferm my fears
Old May 28, 2007 | 04:17 AM
hity645's Avatar
hity645
Did you build the rotissere yourself? How much did it cost? I found some plans online and they said total cost is about $100 for materials. I had a neighbour who works at a steel place give me a quote and they wanted $750-$1000.
I remember seeing some pictures of people who had the car up on the rotissere while they took the floor out. Just make sure the entire frame of the car is supported. And why are you doing the full floor pan? After the headache I went through I would recommened doing the halves.
Old May 28, 2007 | 04:40 AM
mustanglover66
I haven't built the rotisserie yet I just got the plans which look pretty good. I can get all the steel for nothing so cost should be pretty low. I want the full pans for less seams and the half don't have the trans tunnel. I may put subframe connecters on first but that would mean changing 2 frame rails before that right rear and left front anlong with front right floor suport. When I finish the sheet metal the only parts that I'm reusing and the rest of the frame rails, roof, and both fender aprons.
Old May 28, 2007 | 05:18 AM
hity645's Avatar
hity645
If your still worried you can tack weld some beams across then remove the floor.
I was hoping since my neighbour works with steel he could get me some stuff cheap or at no cost...doesn't seem to be the case.
Old May 28, 2007 | 05:22 AM
andrewmp6's Avatar
andrewmp6
yeah is brace the body from door jam to door jam and some cross bracing i rather brace it and it not need it then mess up the car good luck with it floor pans on unibodys are real fun
