Trunk goes CLUNK!
Old May 29, 2007 | 05:11 AM
Guitylerham's Avatar
Guitylerham
Default Trunk goes CLUNK!
Hey guys, I was curious about what may be causing what sounds like my trunk area to make a loud clunk whenever I go over a large bump in the road. It's definitely worse when people ride in the back but it is present even with just a driver. My dad said when he rode in his friend's mustang when he was younger that his car made the same sound. Can this be fixed and is it something I should worry about?
Old May 29, 2007 | 05:15 AM
superdavid's Avatar
superdavid
Default RE: Trunk goes CLUNK!
Can you isolate the noise and give us a little more info? Could be shocks... could be bad bushings... could be the axle hittin the bump-stop...
Old May 29, 2007 | 05:54 AM
Guitylerham
Maybe I can try pushing hard down on the trunk when it's parked to see if I can replicate that. I'll have to check tomorrow but was just curious if this was just a mustang trait. I'll get back with some more specifics soon though.
Old May 29, 2007 | 09:20 AM
JamesW's Avatar
JamesW
Lay underneath while you get someone else torock it up anddown so you can look for things like the exhaust pipe hitting a shock.
Old May 29, 2007 | 09:24 AM
Soaring's Avatar
Soaring
I ♥ Acer
More than likely a loose shock absorber.
Old May 29, 2007 | 10:22 AM
colostang's Avatar
colostang
Air shocks make noises like that somethimes. You running those? Sounds like a shock absorber noise in any event.
Old May 29, 2007 | 12:18 PM
Mykkus's Avatar
Mykkus
Silly thought....are you running the stock spare/jack assembly? If it's loose, it could do something like that.
Old May 29, 2007 | 12:36 PM
paddy187's Avatar
paddy187
I had same issue it was the rear axle vent the one that holds the brakeline on as well hitting the exhaust pipe on my dual exhaust check to see a dimple in the exhaust on that side, PO suck is what i say
Old May 29, 2007 | 05:33 PM
Guitylerham
I do have the stock tire and clamp but no jack in the trunk and that did cross my mind (I have AAA and maybe since I don't have a jack, a spare tire won't do me much good!). Not sure about the shock type though. Be back later.
Old May 29, 2007 | 08:28 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
ORIGINAL: colostang
never run air shocks if you have them more than likely the shock has busted the floor pan and its popping in and out of where its supposed to fit
