Drive Shaft Length
Old May 30, 2007 | 03:07 AM
67SuperSnake's Avatar
67SuperSnake
Default Drive Shaft Length
I havequestion about drive shaft length. My drive shaft goes in to the TKO 600 about 6". I have to pull it back about 2"- 2 1/4" to connect it to the pumpkin leaving about 3 3/4"-4" in the trans. Is that enough, or is that not enough?
Old May 30, 2007 | 03:10 AM
my77stang's Avatar
my77stang
Default RE: Drive Shaft Length
that sounds fine to me. if it was much longer you wouldnt be able to get it in there.
Old May 30, 2007 | 09:23 AM
67 evil eleanor's Avatar
67 evil eleanor
You need a longer drive shaft, 3/4 of an inch of pull back (all the way in then back out 3/4"). With all that power you need all you can get. I like using truck shafts then cut them to fit. Have it balanced too.
Old May 30, 2007 | 11:54 AM
JBradley500's Avatar
JBradley500
you can go to a race shop and for under $200 you should be able to get a 2" diameter chrome molly chaft that is already balanced, had u-joints and is painted.
Old May 30, 2007 | 12:28 PM
68EFIvert's Avatar
68EFIvert
ORIGINAL: 67 evil eleanor
+1
When I had my shaft shortened for my t5 conversion the drive shaft shop sai I only should have 1" of pull back.
Old May 30, 2007 | 12:37 PM
my77stang's Avatar
my77stang
meh, i stand corrected. wouldnt aluminum be the way to go? or even carbon fiber?
Old May 30, 2007 | 03:07 PM
67SuperSnake
This is a balaanced aluminum shaft that was shipped from Unique Performance before I ever had the trans installed. I calledthecompany that made the driveshaft, and was told that since it has the 6" long TKO input yoke, that pulling it out 2" was "OK".
I was not convinced with his statement. And 2" seems to like a lot. Just wondered if anybody else knew for sure.
Old May 30, 2007 | 03:53 PM
my77stang's Avatar
my77stang
i dunno, i suppose the more thats in there the better but personally i prolly wouldnt have even questioned it if i had 4 inches in there
Old May 30, 2007 | 05:22 PM
RGH69's Avatar
RGH69
ok, there is a joke in this conversation somewhere.
Old May 30, 2007 | 05:40 PM
67SuperSnake
ORIGINAL: RGH69
[sm=youreright.gif]
I just ordered one 50 1/4" long [sm=happy046.gif]. 49" wasn't enough. ha ha
Oh yeah, it is 3 1/2" around[sm=thanx.gif]!!! And balanced [sm=bounceybounce.gif]. It can handle a lot of torque[sm=yikesomg.gif].
ha ha. Now... bring it on.
