Monte Carlo Bar questio
Old Dec 30, 2004 | 12:27 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default Monte Carlo Bar questio
I have a 289 with a 2V and the original air cleaner. Do I need to get a curved Monte Carlo Bar, or will the straight one work? It also has air, so the compressor will have to be contended with.
Old Dec 30, 2004 | 12:41 PM
69mach1377's Avatar
69mach1377
Default RE: Monte Carlo Bar questio
Soaring,
I thought the curved one was originally for those cars with an oval air cleaner, but could see how they would help if you have an aftermarket distributor that is larger than stock.
Also, if you already have an export brace, the MC bar will probably have little effect...
Old Dec 30, 2004 | 01:05 PM
Soaring's Avatar
Soaring
I ♥ Acer
Here's an old pic of my engine bay before I cleaned it all up and got all the colors
right. What appears to be an export brace, really isn't. It's in two pieces bolted
together in the middle. I've been thinking about putting in an export brace too.
And yeah, the main reason for the curved MC's is for the oval cleaner, but I just wanted
to check with you guys before I put out the 100 smackers to buy one.
Old Dec 30, 2004 | 01:22 PM
69mach1377's Avatar
69mach1377
$100 seems high for a MCB and depending on how often you fangle around could get in the way, more so than an export brace. The EB are very stiff and prevent shock tower movement with respect to the firewall and each other. A MCB just ties the shock towers together...
Old Dec 30, 2004 | 01:39 PM
Soaring's Avatar
Soaring
I ♥ Acer
So, you think instead of an MC, I should get an export brace instead? You may be onto something there. 'Preciate it....
Old Dec 30, 2004 | 06:09 PM
69mach1377's Avatar
69mach1377
I'm happy with mine...and you've seen what I do to my car.
Installation can be tricky though, you may have to get the front tires off the ground to allow the shock towers to 'sag back out' so the holes in the towers will line up. If so, your alignment may become a little off. The same could be true to get the MCB in as well.
Old Dec 31, 2004 | 05:49 PM
Soaring's Avatar
Soaring
I ♥ Acer
Yeah, I'm familiar with the procedure. Thankee bro...
Old Jan 5, 2005 | 05:18 AM
65_2plus2's Avatar
65_2plus2
Why do you want a MC bar? Or even the Export brace?
If it is for better handling, get both and get a bigger front sway bar and add a rear one. Also go the Sub-frame connector route and 620lb front springs.
I did all that to my 65 and have been happy ever sense.
[sm=icon_guiness.gif][sm=icon_cheers.gif][sm=smiley20.gif]
Old Jan 5, 2005 | 02:04 PM
69mach1377's Avatar
69mach1377
Because old shock towers tend to move around some. Agree about the other items being done also, but they don't address the 'top' portion of the car's structure. When the tops of the towers tilt in or out, your alignment angles change dynamically, no matter how tight the bottom is...bad for handling.
Old Jan 5, 2005 | 06:18 PM
horseshoeing's Avatar
horseshoeing
ORIGINAL: 65_2plus2
Thats the way I went and got the MC bar too. I still need to get thesub-frames connectors
flash_xx
Oct 16, 2015 07:23 AM
UrS4
Oct 3, 2015 06:23 AM
fastbackford351
Oct 1, 2015 12:24 PM
winner99
Oct 1, 2015 10:52 AM
fastbackford351
Sep 12, 2015 09:42 AM
