Rust proofing as you go?????
Old Jun 5, 2007 | 05:04 PM
BB427's Avatar
BB427
Default Rust proofing as you go?????
I have completely exposed the frame on the '66 Vert. The rear trunk pans have been removed and the front floor pans and mid pans are are out. Do you treat the inside of the frame rails before you reinstall the sheetmetal? Is it something that will still treat the metal after welding on it? And what do you use?
Thank you for the help,
Brent
Old Jun 5, 2007 | 05:24 PM
atomsk680's Avatar
atomsk680
Default RE: Rust proofing as you go?????
when i removed my passenger front floorpan there was a little rust inside the frame, so i treated it with por-15
Old Jun 5, 2007 | 05:53 PM
65coupe88hatch's Avatar
65coupe88hatch
+1 I coated both frame rails even though there wasnt any rust inside them I figured it couldnt hurt.
Old Jun 6, 2007 | 02:27 AM
jaw66's Avatar
jaw66
I agreewith them ,but if you can get access to a body shutz gun (it has a long tube and you stick itinside frame rails, rockers etc). and spray a waxy coating on the inside of everything. If you know someone that works in a body shop you might be able to borrow it for this.
Old Jun 6, 2007 | 03:18 AM
andrewmp6's Avatar
andrewmp6
por 15 if you have to weld over it get weld threw primer
Old Jun 6, 2007 | 08:55 AM
kalli's Avatar
kalli
ORIGINAL: jaw66
if you do that, then make sure you don't overfill. Happened a lot to german car manufacturers that the stuff was coming back out when hot outside ruining the look of tyhe car and paint. (doors, latches, hoods .....) .... Volkswagen Golf especially had those problems
Kalli
Old Jun 6, 2007 | 10:29 AM
Soaring's Avatar
Soaring
I ♥ Acer
You want to weld, then treat. POR 15 or any other rust inhibitor will go away into the air with the heat of the weld.
Old Jun 6, 2007 | 02:34 PM
66GTKFB's Avatar
66GTKFB
Check out www.eastwood.com for tools,specialty paint and rust type items. They have an undercoatting system that works fine.
Jim
GPR
Dec 16, 2015 12:21 PM
b8checker
Oct 8, 2015 12:55 PM
b8checker
Sep 30, 2015 07:11 AM
Sep 17, 2015 07:57 PM
showoffzx2
4 Cylinder NA and Turbo
Sep 14, 2015 08:40 PM
