Clutch concerns
Old Jun 6, 2007 | 10:43 AM
Souperman's Avatar
Souperman
Default Clutch concerns
Hey guys. I got my clutch completely dissassembled and I am going to replace the disk (currnetly have a RAM disk). I have a tremec 5-speed with hydraulic clutch. Any suggestions as to what I should put back in. I would like good reliable performance and I do not want to take it apart again for a WHILE. In addition, I could use some pointers on checking the status of my pressure plate and flywheel. (I will try to post pics, but I've had trouble with that in the past.)
Even ifmy flywheel is good, isit worth the money (about $400) to get an Aluminum light-weight flywheel if I am not racing?
Howbout the springs in the pressure plate assembly, should I have them tested, replaced, etc. If so, where. I know nothing about the condition of this car because I have only had it for 2 months and neverdriven it. Thanks guys.
Old Jun 6, 2007 | 11:05 AM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Clutch concerns
You have had that car for two months, and have not driven it? It must be a project car you got for a song then. Hey, here is how you post pictures here. We need some pics to help ya out.
https://mustangforums.com/m_2201606/tm.htm
Old Jun 6, 2007 | 11:08 AM
P Zero's Avatar
P Zero
Ok first things first. As far as I know theres no realy way to test tension on a pressure plate. My experience has been that they hardly ever go bad, but get replaced anyway "just in case". You just look for bent "fingers", scoring or discoloration (blue) on the face where the clutch disc contatcs, or any other physical damage.
Which Tremec do you have in there? TKO? 3650?, also what is the power output of the car? And unless the flywheel is physically cracked, theres no need to replace it. Just get it turned at a machine shop and you should be fine.
As for suggestions on teh clutch disc itself, you could always get one that has more springs in it. Thatll help it "bite" harder.
-P.
Old Jun 6, 2007 | 11:13 AM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: P Zero
-P.
And, if you have a 3650, I have the original clutch plate that came with my 03 Mach that you can have if you pay the shipping. I put a beefed up clutch plate in her.
Old Jun 6, 2007 | 11:54 AM
Norm Peterson's Avatar
Norm Peterson
ORIGINAL: Souperman
Unless you're fairly serious about auto-X or road racing, don't bother. But if you can find a race-oriented shop to resurface your existing flywheel, they may be able to lighten it up a little for you at the same time.
I'm not a drag racer, but with a light flywheel you'd probably want deeper axle gears to help your launch - without being so deepthat having enough rpm capability to avoidany need to shift into 5th becomes a problem.
Norm
Thunderball
15
Nov 22, 2015 11:49 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
Teddi
Sep 29, 2015 12:24 PM
junior04
Sep 28, 2015 10:53 AM
MacSerio
Sep 27, 2015 01:05 PM
