stoker
Old Jun 6, 2007 | 04:24 PM
dlynch's Avatar
dlynch
Default stoker
so has any one on here stroked a 351w motor? if so what type of kit did the use and how much was the the hole thing? and are they happy with it?
Old Jun 6, 2007 | 07:19 PM
onegreedy's Avatar
onegreedy
Default RE: stoker
BUMP, i am interested in this too
Old Jun 6, 2007 | 07:31 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: stoker
Gentlemen, I haven't done this either, and hopefully someone on here who has done this can help you. If not, my suggestion is that you google search 393 Windsor Stroker Kit and see how much info you can get from that search. The reason for 393, is that is the most common 351 stroked engines./
Old Jun 6, 2007 | 07:42 PM
BB427's Avatar
BB427
Default RE: stoker
I just finished my Windsor stroker.
408 Cubic inches
roller block
4.030 bore
4.00 stroke
Scat Crank 4340
Eagle rods H beam
KB dished 9-1 pistons
AFR 185 CNC portedaluminum heads
Milodon pan and windage tray
Lunati Cam and lifters
Comp Cams aluminum roller rockers
MSD billet dist.
fabricated valve covers
Edelbrock water pump
March pulleys
Great motors, tons of reasonable parts avail. , and they make a lot of power. For a change you can build a Ford for the price of a small block Chevy.
Over 500HP
about 6K
Brent
Old Jun 6, 2007 | 07:47 PM
P Zero's Avatar
P Zero
Default RE: stoker
The largest stroker for the 351 Ive seen was a 436.
-P.
Old Jun 6, 2007 | 07:53 PM
JMD's Avatar
JMD
Default RE: stoker
ORIGINAL: dlynch
Just built one have not started it yet,
Scat Forged Crank
Scat H Beam Rods
KB Forged Pistons
Mahle Rings
$1,200 for rotating kit, balanced.
With H Beams clearancing the block is not needed,
Old Jun 6, 2007 | 11:39 PM
white69mach1's Avatar
white69mach1
Default RE: stoker
fordstrokers.com is who i bought mine from the owner seems like a pretty guy he comes around the forums sometimes
Old Jun 6, 2007 | 11:51 PM
maverick75's Avatar
maverick75
Default RE: stoker
ORIGINAL: P Zero
-P.
the biggest ive seen was a 600HP 427svo w/300HPshot
...ive hered they make a kit to stroke it to 460 but i've never seen it
Old Jun 6, 2007 | 11:59 PM
my77stang's Avatar
my77stang
Default RE: stoker
fullauto is a member here who sells stroker kits, he does rotating assemblies for the 302 blocks for 750 bucks so im guessing a 393/408/427 stroker kit wouldnt be too much more.
i've never heard of arp heads, do you mean AFR heads with ARP bolts?
Old Jun 7, 2007 | 12:02 AM
mustanglover66's Avatar
mustanglover66
Default RE: stoker
I work for a stroker crate engine builder 432 is about as far you want to go with a stock block but up 460 is posible. Here is the website http://tandlengines.com/
