power steering ?!!!!!!!!
Old Jun 7, 2007 | 09:27 AM
supermanzx9r's Avatar
supermanzx9r
Default power steering ?!!!!!!!!
so i finish the power steering setup on my car (67 coupe) and i started the car and the power steering pump is scream like crazy WTF.............pls dont tell me the pump is bad ... because i bought this setup off of ebay and so far i had to replace every part on it except the pump i an it looks like i might have to (damn you ebay )....LMAO
Old Jun 7, 2007 | 10:13 AM
mySAVIOReigns's Avatar
mySAVIOReigns
Default RE: power steering ?!!!!!!!!
Was it only screaming when you turned the wheel? Or just screaming when you started the car?
If it's not the pump, might be a pulley or belt too loose or something....you have fluid in it right?
Old Jun 7, 2007 | 12:02 PM
supermanzx9r
it was screaming alittle and alot when i truned the wheel and yes there is fluid in the pump and i prime the system ..........[&o]
Old Jun 8, 2007 | 08:41 PM
ponyX65's Avatar
ponyX65
sounds like thebearings in the pump are bad, if it was 're-built' then they didnt put it back together correctly. from what you are say it sound like you have the same problem i had, just bite the bullet and have a trusted shop do th e re-build for you should be under 100 bucks or so...well thats what i paid and havent had single problem with it.
Old Jun 8, 2007 | 09:04 PM
Soaring's Avatar
Soaring
I ♥ Acer
Something is too tight inside the pump probably. Yeah, bite the bullet.
Old Jun 9, 2007 | 04:01 AM
gothand's Avatar
gothand
This may be a stupid question, but did you bleed the system?
Old Jun 9, 2007 | 05:21 AM
andrewmp6's Avatar
andrewmp6
mine will scream if i turn it lock to lock parked but yeah sounds the pump is bad or rebuilt wrong
CS2007
Jun 25, 2019 09:45 PM
KingRando
Oct 2, 2015 08:06 AM
ChampInSD
Oct 2, 2015 04:55 AM
Sep 25, 2015 06:58 PM
