harmonic balancer ,, how do I get the thing off..
Old Jun 8, 2007 | 11:27 AM
boogerschnot's Avatar
boogerschnot
Default harmonic balancer ,, how do I get the thing off..
I know the simple answer is to go buy a puller,, but I dont want to spend the money. So any suggestions on how to get it off without the puller, and without breaking the thing?
Old Jun 8, 2007 | 11:49 AM
atomsk680's Avatar
atomsk680
Default RE: harmonic balancer ,, how do I get the thing off..
rent a puller from autozone
Old Jun 8, 2007 | 11:52 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
+1 just give them a deposit and get your money back when u finish
Old Jun 8, 2007 | 12:25 PM
fastbackford351's Avatar
fastbackford351
Foghorn Leghorn
Make sure that you use a harmonic balancer puller and not a gear puller. If you use a gear puller youcould easilyscrew up the balancer by pulling it apart.
Ask me how I know that bit of information....
Norm Peterson's Avatar
Norm Peterson
Get/rent/borrow the puller. Most of them can be used to install balancers in one way or another, so you'll actually get two uses out of it. (Yes, I know people use a hammer for installation, but that's really not the best way to do it.)
Norm
Old Jun 8, 2007 | 01:27 PM
Soaring's Avatar
Soaring
I ♥ Acer
Why would you opt to not do it the right way. Get a puller from autozone as Stephen suggested.
Old Jun 8, 2007 | 01:30 PM
dozierstang's Avatar
dozierstang
Go buy a puller, it is adjustable and you can use it for several things. And they are not that expensive. As far as installing the balancer, use a soft deadblow hammer and TAP it. Get it onjust enough to get some threads started on the bolt. Put some grease around the head of the bolt and use it to install.Turn the bolt slowly and evenly work the balancer back on.I do this to all that I have removed and installed. Technique also works good for pinion yokes.
Old Jun 8, 2007 | 02:27 PM
my77stang's Avatar
my77stang
free tool rental FTW!!!!
seriously, with it being free - how can anyone afford to NOT use the proper tooling?
Old Jun 8, 2007 | 06:01 PM
boogerschnot
well I guess,, I will get the puller afterall... Thanks guys..
Old Jun 8, 2007 | 06:53 PM
atomsk680's Avatar
atomsk680
i rented a puller from autozone, then shortly after my dad showed me that we actually have 3 different pullers[&:]
