Headliner is it a huge pain?
Old Jun 8, 2007 | 10:54 PM
66JameStang's Avatar
66JameStang
Default Headliner is it a huge pain?
Well i need to replace my headliner and I was wondering would you just let a shop deal with it or is it simple enough to do yourself. I plan on doing my seats and everything to cut down cost.
Old Jun 8, 2007 | 10:58 PM
highhilleer's Avatar
highhilleer
Default RE: Headliner is it a huge pain?
To do it right you need to remove the front and back glass, which isn't too hard. Installing the headliner is a bunch of fussy work but not too bad. Make sure you keep the rods in order and note the hole that each rod goes into as you are removing them. Be sure to heat the headliner in the sun before starting the install. If you think youcan reupolster sears then you should have enough confidence to do the headliner.
Old Jun 8, 2007 | 11:00 PM
66JameStang
Cool thanks I did not know you had to remove the glass that helps me ..
Old Jun 8, 2007 | 11:50 PM
atomsk680's Avatar
atomsk680
do you HAVE to remove the glass?[]
Old Jun 9, 2007 | 12:25 AM
mySAVIOReigns's Avatar
mySAVIOReigns
yep
well...you don't have to, but it will look like crap. Bigtime
Old Jun 9, 2007 | 12:34 AM
Soaring's Avatar
Soaring
I ♥ Acer
Yep, you have to remove the glass to replace the headliner on a 65-66.
Don't you knuckleheads read the FAQ?
Old Jun 9, 2007 | 01:24 AM
atomsk680's Avatar
atomsk680
ORIGINAL: Soaring
only when i dont feel lazy
i guess i will let a shop install my headliner
Old Jun 9, 2007 | 01:29 AM
66GTKFB's Avatar
66GTKFB
No you don't need to remove the glass. Most shops replace headliners without glass removal. I had mine done by a retired Ford assembly line worker who, as it turned out, installed headliners for over 20 years at the San Jose assembly plant. If you remove the glass, you will need new weatherstrip and several tubes of 3M sealant. Plus there is always the chance that the glass will break. I hate it when that happens.
Jim
Old Jun 9, 2007 | 03:47 AM
gothand's Avatar
gothand
NPD sells a headliner installation tool p/n 935-2 which allows you to install it with the glass in place.
To the OP, I'd go ahead and give the install a try. The headliner is only about $30, so even if you totally screw it up, you're not out too much money. Don't forget the adhesive as well.
Good luck!
Old Jun 9, 2007 | 04:34 AM
bradleyb's Avatar
bradleyb
I pulled my headliner off and I didn't have to take the rear glass out - it just folded under the weatherstripping. I am going to try and change it without taking the glass out this weekend (I have the windshield out but don't want to take out the back glass)
