dual carbs?
Old Jun 10, 2007 | 04:31 AM
390bigblock's Avatar
390bigblock
Default dual carbs?
how much money would it cost to change my 390bigblock to a dual carb and a blower and were can i buy the stuff at? you can never have to much power[sm=lol.gif]
Old Jun 10, 2007 | 04:43 AM
andrewmp6's Avatar
andrewmp6
Default RE: dual carbs?
first you need to build up the engine to hold the blower or youll float the valves bend rods.http://www.dyersblowers.com/157.html has blower kits for the fe either a 671 or a 871 the 671 is small only a single carb the 871 is a dual carb
Old Jun 10, 2007 | 04:46 AM
DenDen's Avatar
DenDen
Lots.
you have to change a lot of things in that engine to take a blower.Pistons have to be forged.Cam has to be for a blower engine.You are looking at a large chunk of change to make it a semi reliable motor.When you think of blowing air into an engine,think of an oxy acetalyne torch.Your stock valves will look like someone had a torch such as this inside your engine.
Just for a gigle,go into a machine shop that does engines and ask how much cost is required to do this type of engine.Ill bet the first thing youll hear is 'oooooh'. If its under 10 000,Id be surprised.
Old Jun 10, 2007 | 04:51 AM
andrewmp6's Avatar
andrewmp6
i have a merlin 572 big block in my corvette i spent about 8k on the engine thats a chevy there big blocks are alot cheaper.how much power do you want and whats your budget
Old Jun 10, 2007 | 05:14 AM
390bigblock
well im not looking for 2 much more power im around 550 hp right now... but know i dont think im going to have the money i didnt know it was going to cost so much...
Old Jun 10, 2007 | 09:54 AM
andrewmp6's Avatar
andrewmp6
you can run 2 4 barrels or even the 3 2 barrel set up the blower kit is pricey
Old Jun 10, 2007 | 03:55 PM
390bigblock
ya i think im better off keepingg my single carb and using the money for some body parts and paint
Old Jun 10, 2007 | 09:21 PM
67mustang302's Avatar
67mustang302
If you have a n/a 390 making 550hp you don't want to screw with putting a Roots blower on it, cuz I imagine you already have pretty decent compression. You'll most likely just destroy your engine, burn holes in pistons, crack pistons etc. It's gonna want to detonate, Roots blowers run hot and hate high compression, and it's absolutely CRITICAL you tune it right, which is hard with a carb....you don't go rich enough, especially with higher compression, and boom.
Old Jun 10, 2007 | 10:44 PM
dcohen's Avatar
dcohen
you can get 550 out of a 390 without a blower my friend
Old Jun 10, 2007 | 10:47 PM
390bigblock
ya i got it dynoed 2 time one time last year and 2 years ago, both times they were around 550
