backup lights not working
Old Jun 10, 2007 | 11:16 AM
alderpulp's Avatar
alderpulp
Default backup lights not working
I can not seem to locate the backup light switch on an automatic transmission to my 68 coupe. Bulbs are good, just no power back to lamps. Is switch on transmission itself? Also, all of my fuses are good, but no back up light fuse is listed. Do they share a fuse with some other lights?dw
Old Jun 10, 2007 | 12:53 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: backup lights not working
The switch is near the rear of my manual tranny. The reverse linkage has to turn it on and off, so just check the linkage on the tranny and see if you can locate it. The switch itself is pretty expensive.
Old Jun 10, 2007 | 03:01 PM
66GTKFB's Avatar
66GTKFB
On an automatic transmission, the back-up lights switch is part of the neutral start safety switch. It is on the left hand side of the transmission and costs about $31.00 (NPD 2007 Pg105). Wiring comes up to afour pin connector in the engine compartment to the right of the master cylinder.
Jim
djbigskrilla
Sep 20, 2022 01:04 AM
movielover40
Aug 27, 2015 10:13 PM
bigdaddy51200
Aug 19, 2015 05:09 AM
jjwinel78
Aug 17, 2015 03:34 PM
philster0306
Aug 10, 2015 11:33 AM
