New Edelbrock Carb!!
With much deliberation of all the information on this forum about Carbs I boughta 600 CFM, manual choke Edelbrock No. 1405 Iput it on my 67, 289 A code.. It hooked up very easy .With afew adjustments, one being the secondaries where sticking open do to a bent spring lever that must of happen during shipping. The car runs amazing, no trouble starting hot or cold. The car churpsthe tires from 1 to 2 and when I got my foot in it. I am very pleased with it so far .Just want to let the forum know it really help me in make a desicion.Thanks to all for the input. Rob
Did you put it on the stock intake, and do you still have the stock cam? I need to either refurbish my Motorcraft or get a new carb, but was thinking of doing the intake and carb at the same time. Glad to hear the car is running good.
ORIGINAL: solidGas
Could you tell me the reason you replaced it? I am having problems with my carb running too rich and therefore if i give it alot of gas it hickups and even bogs itself down enough to stall it when i accelerate quickly...I'm thinking of getting a new carb soon as well, i hope this is the cause of my problems...
EDIT: oh P.S. it also is having a little problem starting up in the morning
ORIGINAL: restomod87
And, unless you have a lot of mods on your engine, you don't need a 600 cfm carb.
If you look down into your carb, you will see the venturi (round hole). That hole is a certain diameter depending how much air you want to draw into that engine. If you have a stock engine and you put on a carb that has too big of a venture you will be drawing in more air than is needed. You will need more gas to mix with that extra air, and you will need a hotter spark to burn that extra gas and air mixture that your engine was not designed to burn. Just throwing on a new and bigger carburetor is certainly not the answer.
mods to increase power ( and typically fuel consumption ). I would not change the carb, if I did not have some headers to free
the extra gasses at the other end. Personally I like working on carbs, as its one piece you can take off the car, find a clean work area,
and see how it works. If you have a carb overhaul kit it can be a fun afternoon job.
Jav
No there is no smell of gas. Hope you can figurethis out . You got alot of suggestions. I replaced an oldHolleythat was in bad shape beyond repair,someone screwed it up before me,the secondaries would stick open sometime abit or wide open after I stopped. Have you called Edelbrock help tech line.
ORIGINAL: Mustang owners Dad
UBY289,
My son just resently installed a 1405 also but his emits a lot of gas fumes. Does yours?
UBY289,
bradleyb
Nov 27, 2015 07:50 PM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
jaiidutch
Sep 14, 2015 10:29 AM
tramphardrocker
Sep 13, 2015 08:56 PM
