its official
Old Jun 15, 2007 | 10:49 PM
atomsk680's Avatar
atomsk680
Default its official
wiring sux, well not just wiring, it could be this heat and the fact that the mosquitos are out now and bugging the crap out of me. BUT there is a pus side, i almost have all the old wiring out. then in goes the fusebox and im going to wire in the back section, meaning the tailights and whatnot, then call it a day and do as much as i ca the next day.
Old Jun 15, 2007 | 10:59 PM
baddog671's Avatar
baddog671
Default RE: its official
Good job, I knew you were going to have some fun with that
Old Jun 15, 2007 | 11:04 PM
JamesW's Avatar
JamesW
Yeah... it definately sucks working under the dash with no air and 200% humidity we've been having.
Go to Wallyworld and buy the biggest fan 50 bucks will get you and keeping it blowing inside the car while you're working... about the only way to keep the skeeters off...
Old Jun 15, 2007 | 11:21 PM
green_blurr's Avatar
green_blurr
I got a wiring manual so i can understand the basic outline of the wiring in the car that will help you out alot.
Old Jun 15, 2007 | 11:22 PM
atomsk680's Avatar
atomsk680
i have no idea how im gunna rehook up all this heater thing, i dont think it worked to begin with, but as i kept tearing and cutting more wires out, i found that it wasnt really hooked up at all and most of the wires were missing or broken
Old Jun 15, 2007 | 11:25 PM
fastbackford351's Avatar
fastbackford351
Foghorn Leghorn
Are you going to use a factory repop harness or something like a painless setup to rewire it?
If you are going to use a Painless or some similar setup, make sure you save all of your connectors from your old harness. Or at least those that are still in good serviceable condition.
Old Jun 15, 2007 | 11:29 PM
atomsk680's Avatar
atomsk680
yea im using a painless whole car harness and im keeping all the connectors anyway just in case i may need them later
Old Jun 15, 2007 | 11:35 PM
JamesW's Avatar
JamesW
Was the Painless harness specifically for your year/model mustang, or was it one of the street rod types?
Old Jun 15, 2007 | 11:41 PM
atomsk680's Avatar
atomsk680
specifically for 69/70 mustang
Old Jun 15, 2007 | 11:53 PM
JamesW's Avatar
JamesW
Sounds like it should fix your heater wiring issues for you then....
