289 or 302?
Jun 21, 2007 | 01:16 PM
289 or 302?
Is there any way to tell a 302 from a 289 by just looking at it.
Jun 21, 2007 | 02:15 PM
RE: 289 or 302?
on my 302 there is a metal tag that says 302. so if that is still on there you can tell.
Jun 21, 2007 | 02:25 PM
RE: 289 or 302?
You need to pull the starter and look at the casting number.
Jim
Jun 21, 2007 | 10:09 PM
RE: 289 or 302?
6 bell housing bolts is definitely a 302.
Otherwise, the crank is really the only way to know. Just because a block has a 289 casting number, doesn't mean someone hasn't tossed in a 302 crank in the block's 40+ year life.
Jun 21, 2007 | 10:42 PM
RE: 289 or 302?
"6 bell housing bolts is definitely a 302"
Not so. I havetwo 289 blocks with 6 bolt bellhousing. One is a 1966 and one is a 68.
Jun 21, 2007 | 10:47 PM
RE: 289 or 302?
I believe i recall the heads on my 289 having 289 cast into them under the valve covers, and the block in the valley pan.
Jun 21, 2007 | 10:55 PM
RE: 289 or 302?
Does it really matter? Basically, they are the same engine. The 302 has a little longer stroke, that's all. BFD.
Jun 21, 2007 | 11:54 PM
RE: 289 or 302?
289 > 302
Jun 22, 2007 | 12:02 AM
RE: 289 or 302?
Quote:
ORIGINAL: 67coupe
I agree. My car came with a 289 that had the 6 bolt bellhousing.
bradleyb
Nov 27, 2015 07:50 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
GTJIM
Sep 23, 2015 09:59 AM
jaiidutch
Sep 14, 2015 10:29 AM
ryland
Sep 13, 2015 12:35 PM
