vacum advance question?m
Old Jun 22, 2007 | 01:44 AM
Loza_69Mach1's Avatar
Loza_69Mach1
Default vacum advance question?m
I have a 69 mach 1 and it was a 2bbl carb in and i got a 4 bbl and new intake.. all edelbrock. 600cfm carb. well the guy at the shop told me the vacum advance on my dist. makes it to advanced where it makes a clickin sound. and he said just to leave it disconncted. Have any of you guys ran you distubor like these? let me know if i need to explain some more.. thanks
jr
Old Jun 22, 2007 | 01:51 AM
my77stang's Avatar
my77stang
Default RE: vacum advance question?m
you need it hooked up, the vacuum advance helps your car get up and go - it also gives you brtter gas milage.
what do you mean by a "clickin sound"??
Old Jun 22, 2007 | 02:17 AM
Loza_69Mach1
yeah it makes a ping sound.. like if you have the timing off... he told me the timing was at 42degrees and he droped it down to 9 degrees.. he said the vacuum advance needs tighter centrel curve on the distributor. what do you know about that... he said because the distributor i have which is a new stock one he cant. i have to get another one. thanks for the time
jr
Old Jun 26, 2007 | 09:16 AM
Norm Peterson's Avatar
Norm Peterson
Sounds like you could use an adjustable vacuum advance kit. Basically this mechanically limits the amount of vacuum advance that can be added by the vacuum diaphragm. Check over at CraneCams.
Norm
Old Jun 27, 2007 | 05:12 AM
mat11089's Avatar
mat11089
42 for total timing or base cuz for total that wouldnt be too bad.But yeah i see it all the time on customer cars
Old Jun 27, 2007 | 08:38 AM
paddy187's Avatar
paddy187
Ok I may be reading this wrong and norm and my77 have better knowledge than me but you need vaccuum advance to have the car running good the problem when changing the carb is what vacuum to use, more specifically were to find it. I think you will have a vacuum advanced dizzy on your car and not mechcanical (which i don't know much about) therefore you need a timed vaccum port and not a manifold vacuum port as you need different vacuum at different revs, i.e. no vac on idle vac on higher rpms.
9 degrees is ok for static timing (at idle) and 42 sounds ok on advance to me so i think you may have misheard the guy or he is talking rubbish, as I doubt your car would have 42 degrees of static timingit probably would notrun at 42 degrees static timing. I hear someone trying to get some cash of you for no reason.
StalkerGT
Sep 25, 2015 02:41 PM
jaiidutch
Sep 14, 2015 10:29 AM
cbird1177711
Sep 3, 2015 08:43 PM
