What is the problem?
Old Jun 24, 2007 | 10:59 AM
Turbine Cowboy's Avatar
Turbine Cowboy
Default What is the problem?
Hi all,
Just finished installing both new front (ballanced) drums new set of shoes, springs, adjusters .... the works.
On braking, I get annoyoing vibrations from the front wheels. Can't tell from which side---feels the same from L/R
Front wheels are freshly ballanced as well.
Shoes were tested for fit against the drums before instalationand it did look good.
WHAT ISTHE PROBLEM?
How do I lose those vibes?
Thanx
TC
Old Jun 24, 2007 | 11:09 AM
andrewmp6's Avatar
andrewmp6
Default RE: What is the problem?
could be a bad wheel cylinder thats the only thing you havent replaced right.what kinda vibration is it like a out of blance tire or whole car shakes.
Old Jun 24, 2007 | 11:52 AM
Turbine Cowboy
The whole front of the car shakes. (steering wheel as well) Both cylinders were cleaned and rubber discs were were replaced
TC
67coupe's Avatar
67coupe
One of the hubs may not be fully seated in the new drum. Pul the tires and check the roll out?
Old Jun 24, 2007 | 12:19 PM
JMD's Avatar
JMD
You might need to grease your brakes,,,,,,,,,,,
Just kidding.....
Maybe they just need some time to break in, I remember that they used to "arc" brake shoes to get a better initial fit in the drum.
Old Jun 24, 2007 | 02:57 PM
Soaring's Avatar
Soaring
I ♥ Acer
There are two different shoes on each side. Each side should have a short shoe in front and a long shoe in back. Is that how you put them on, or did you put two short ones on one side and two long ones on the other side?
Old Jun 25, 2007 | 02:19 AM
Turbine Cowboy
Yes . I did pay attention to the primary and secondary shoes and as far as I can tell they are all installed correct.
I alsodid thinkof this mightas a thing of initial use that will go away after a while... I guess I will have to wait and see b/c everything seems to be right. The wheels as well, they both sit tight on the drums.
Gremlins......
TC
Old Jun 25, 2007 | 05:09 AM
andrewmp6's Avatar
andrewmp6
does it shake always and get worse at speed or is it only when stopping.
Old Jun 25, 2007 | 07:20 AM
Turbine Cowboy
Only when stopping and smoothes out whenat realy slow speeds.
TC
Seanam
Oct 4, 2015 10:15 AM
marc954
Sep 29, 2015 03:05 PM
mdj89
Sep 23, 2015 08:49 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
