Roller Rocker Arm Question
Old Jun 29, 2007 | 01:40 PM
JohnCalvin's Avatar
JohnCalvin
Default Roller Rocker Arm Question
I've built a 302 roller in my garage and going to install it next week... I put on a set of aluminum roller rocker arms and did the whole set up, valve closed, tighen til rod is tight, then half turn and lock... That was a week ago, yesterday i was checkin them out and noticed some of the push rods were loose enough i could turn them by hand.
Do i need to retighten them? Is that just because the Hyd Lifters i'm using have lost the oil inside so they are no longer pumped up? Just leave them and the oil will pump them back up? when i pulled my 289 the other day i noticed that those rods i could easily turn with my hands, is that normal? Don't think the valve covers have been off the 289 in many many years. So should i retighten or just leave them???
Old Jun 29, 2007 | 02:22 PM
my77stang's Avatar
my77stang
Default RE: Roller Rocker Arm Question
leave em. if its new stuff they havent been pumped up with oil yet.
if you start it and it doesnt quiet down after a couple minutes then look into readjusting - but i think you'll be ok cause it sounds like you did it correctly.
Old Jun 29, 2007 | 02:59 PM
JohnCalvin's Avatar
JohnCalvin
Cool beans... guess i'll leave them for now! it's not like they aren't really easy to adjust later
Old Jun 29, 2007 | 03:53 PM
67mustang302's Avatar
67mustang302
Yeah, the lifters prolly just bled down. It might tick a bit when you start it up, but should go away after a few moments. Like my77stang said, if it doesn't quiet down after a bit, then readjust
Old Jun 29, 2007 | 06:02 PM
my77stang's Avatar
my77stang
yay for my correctness
Old Jun 30, 2007 | 12:56 AM
67mustang302
lol. On a side note, my Crane 1.7rr's are noisy lil turds
guitarman376
Oct 11, 2015 01:47 AM
69MustangCoupe393cid
Oct 3, 2015 10:33 AM
uedlose
Sep 30, 2015 08:01 AM
GimpyHSHS
Sep 18, 2015 12:27 PM
FivePointToTheOh
Sep 14, 2015 03:35 PM
