Fluids colors
I have a small leak - the liquid is pinkish red - toward the middle driver's side. Anyone know what that is?
Also can someone give me a rundown of the colors of the various liquids (green, brown, etc) that are used in the Mustang?
Thanks
Thanks
fluid colors lets see
oil= brown to black depending on how dirty it is
trans fluid= red automatic and thick brown manual
power steering = red
coolent= green, yellow, or red depending on the type you use
rearend lube same as manual trans.
Not a big gushing puddle but definately lots of drops as it sat for several days (makinga 12" cirlce). The color is a clear red/pink located on the driver's side, under the streering wheel column)
Whether power steering or transmission, is itsafe to drive until I get it looked at? By the way, how much fluid does the power streering contain? How much fluid does the transmssion contain?
Thanks
Oh, one more thing, are old Mustangs prone to leaking?
Thanks
Transmission can contain about 9 qts. if I remember correctly, but the torque converter holds about 5 of that, and so if you were to drain the pan, you'd just have to fill it back up with about 4.0 - 4.5 qts. Power steering I'm not sure, but a manual probably has it listed
depends what the leak is causing.. it can be simple.. if on of the hoses is leaking. .. some more work it is the control valve (rubbers leaking) ..
from your discription i don't think it is the steering pump since that is located more forward.
but you can crawl under the car and check if you can see oil at one of those parts..most of the time you can notice the spot... feel with your fingers under the controvalve.. hoses connections to control valve and steeringpump... steering cylinder .
with that little oil you have seen on your floor driving wouldn't be a prob.. just to be sure check the level in your transmission and steeringpump
arthur
arthur
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
Sep 25, 2015 06:42 PM
