Passenger Side Squeak
Old Jul 5, 2007 | 10:21 PM
kaiser18's Avatar
kaiser18
Default Passenger Side Squeak
On the passenger side of the vehicle at the front wheels I am getting a noisy squeak when going over the slightest bump. I greased every joint that had a injection nipple, ( didnt touch was the ball joint because I have no idea hot to grease it) Even after doing this it was still emitting a squeak. I listen carefully and it sounded like the noise was coming a much higher place no where near all the joints below. Any ideas?
Old Jul 5, 2007 | 11:22 PM
JamesW's Avatar
JamesW
Default RE: Passenger Side Squeak
Most likely coming from your upper A arms. They squeak because the shaft does not get adequate grease from the end cap zerk fittings. A common modification to these arms is to cut a groove into the threads to allow for a grease path.
If you can't get grease into it through the upper zerk fittings, you may end up having to rebuild the upper arms.
Old Jul 6, 2007 | 02:33 PM
nigel68's Avatar
nigel68
The same happened to me, after a 140 mi. trip. It starts with a head-turning squeak, and I notice squeak was coming from the upper A-arm like JamesW said. Probably, motor heat after highway riding dried the bushings.
There are a couple of bushings on the rod connecting A arm to frame, best will be change the complete arm. As an immediate solution, I sprayed a lot of silicone oil (silicone makes rubber softer and softer, never dries)...the squeak disappeared. It seems easy...but as I wrote, change the arm ('cause time needed is the same if you change bushings), should be the best.
PaulH2
20
Jan 31, 2016 09:48 AM
chrisdbassplayer
Oct 13, 2015 06:53 PM
UrS4
Oct 3, 2015 06:23 AM
ChampInSD
Oct 2, 2015 04:55 AM
Sixer4Life
Sep 29, 2015 07:03 PM
