need to find a spring compressor
Old Jul 6, 2007 | 12:49 AM
eep4life's Avatar
eep4life
Default need to find a spring compressor
does any one know of a web site that carries a spring compressor that mounts inside the spring rather than on the outside. im trying to compress my front end suspention spings... and no local auto shop by me has them...
Old Jul 6, 2007 | 12:57 AM
dnswwood's Avatar
dnswwood
Default RE: need to find a spring compressor
Napa usually carries them ,if not I'm pretty sure Npd does.One trickI learned with mine is to add a piece of pipe about 5 inches long to the side that has the bolt so that the head of the bolt will stick up through the upper shock mount.That way you dont have to be down there under the fender with the spring compressed.Be careful with those springs,a compressed spring letting loose can maim or kill you.
hope this helps
Jeff
Old Jul 6, 2007 | 01:03 AM
JMD's Avatar
JMD
ORIGINAL: eep4life
I have a very safe way to compress springs with an engine hoist and a legnth of 5/16" chain..... but....
Anyway, we were able to rent one from NAPA that fit inside, it scared the s*** out of me and I did not use it....
Old Jul 6, 2007 | 01:06 AM
JamesW's Avatar
JamesW
http://cgi.ebay.com/ebaymotors/Inter...35608709QQrdZ1
Old Jul 6, 2007 | 01:41 AM
66GTKFB's Avatar
66GTKFB
Here are two pictures of my home made one, the proto-type in fact. It is modeled after one supplied by Snap-On Tools. This one compresses the spring in the car. The ones that do it outside the car - suck. Use the serch feature on this forum for the particulars.
Jim
[IMG]local://upfiles/64738/BC7C60A82B3E43D19598D9E768A5DFC6.jpg[/IMG]
[IMG]local://upfiles/64738/D257D09612BE4789B1049C9D595C82C9.jpg[/IMG]
Old Jul 6, 2007 | 09:32 AM
65StangFB's Avatar
65StangFB
Depending on whether you are going to need them again, some parts stores will loan them for free. Autozone and Discount auto parts now have a loan a tool program. I bought the spring compressor for $50 and I had the choice to keep it or return it when I was done for a full refund. Check into it for many other tools as well.
Old Jul 6, 2007 | 03:13 PM
arthur's Avatar
arthur
a simple home made i used for my coils:
http://www.mustang.artho.nl/image-4-5.html
arthur
Old Jul 6, 2007 | 05:01 PM
66GTKFB's Avatar
66GTKFB
Aurthur,
I like it. What holds the two rods to the spring saddle?
Jim
Old Jul 6, 2007 | 05:45 PM
jlg2002's Avatar
jlg2002
I rented a set from autozone here in socal. they barely fit the inside of the coil. Good luck.
Old Jul 6, 2007 | 09:48 PM
baddog671's Avatar
baddog671
Got mine off of ebay for 23 bucks. Look it up, felt very safe using it...
