fuel cells
Old Jul 6, 2007 | 03:28 AM
eep4life's Avatar
eep4life
Default fuel cells
what is a fuel cell, what does it do different from a normal gas tank... and are they a good investment
Old Jul 6, 2007 | 03:34 AM
atomsk680's Avatar
atomsk680
Default RE: feuel cells
fuel cells gerenally are just bigger gas tanks, they can be stronger then a normal gastank, usually used for race applications so the car wont run out of gas right before a race
Old Jul 6, 2007 | 09:46 AM
JamesW's Avatar
JamesW
ORIGINAL: atomsk680
Fuel cells are aluminum, steel or poly tanks which house a fuel "cell"...or bladder. These can be of any size...typically between 12 and 20 gallons. This fuel resistant neoprenebladder is designed tocontain the fuel in case of an accident. Some cells have foam internally to stop the fuel from sloshing around.
Old Jul 6, 2007 | 02:50 PM
dodgestang's Avatar
dodgestang
ORIGINAL: atomsk680
Less correct
ORIGINAL: JamesW
More correct
Old Jul 6, 2007 | 03:54 PM
atomsk680's Avatar
atomsk680
Old Jul 6, 2007 | 04:39 PM
67Sally's Avatar
67Sally
To put it simply they're stronger, more expensive,usually have more volume, and are most commonly used in race applications. If you are concerned about trunk space don't bother .
Old Jul 6, 2007 | 06:08 PM
dodgestang's Avatar
dodgestang
ORIGINAL: 67Sally
You can also buy a fuel safe fuel cell that is a bolt in replacement for the stock classic mustang gas tank and does nothing to your trunk space
It is also 3x the price of other fuel cells, so you pay for that luxury. But fuel cells are also rated for specific race classes which drives some of their costs. If this is a street car a fuel cell is generally not a good idea because of both the cost and the maintenance, the bladders do where out and the foam pads break down over time and can gum up your fuel filters and lines.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
Sixx
Oct 5, 2015 07:36 PM
svfetter
Oct 5, 2015 11:39 AM
mrappe
Sep 26, 2015 10:16 AM
