Wheel stud size and other problem
Old Jul 6, 2007 | 05:29 PM
St3mpy's Avatar
St3mpy
Default Wheel stud size and other problem
Quick question: Does anybody know the size of stock wheel studs? I was trying to mount up my TT D's, but there wasn't enough thread left to thread the lug nut safely. Before anyone tells me to check myself, my stang is off getting the headliner and windshields installed, so I won't have it back until Monday. Man, I've got alot of work to do though. On the way to the glass shop, when I hit about35-40, the entire car would shake until I came to a stop. This is the first time I've really driven it since I've gotten it (been doing body work and stuff). It seemed like it originated from the rear, but it wasn't a driveshaft shimmy, it was to violent to be that. I also didn't feel it in the steering wheel. It felt like I was about to lose a wheel. Anyways, if anyone knows the wheel stud size, that'd be great. I need to get them ordered soon.
Forgot to mention it's a 67
Old Jul 6, 2007 | 05:37 PM
66GTKFB's Avatar
66GTKFB
Default RE: Wheel stud size and other problem
Depending on the year of the car - I'll use a 66 with drum brakes as reference, 1/2-20X1 1/2 long front and 1/2-20X1 5/8 rear.
Jim
Old Jul 6, 2007 | 05:39 PM
jlg2002's Avatar
jlg2002
My 66 coupe c code has 1 1/4in. long wheel studs. The shimmy you describe sounds like dynamic unbalance of the rear wheels and tires. It can be caused by a really bad tire balance, a bad tir (out of round), a bent rim, or a loose rim on the axle.
Old Jul 7, 2007 | 12:50 AM
St3mpy's Avatar
St3mpy
Looks like I'll be going with 2inch studs then. I was looking at the lug nuts that you use for Cragar SS wheels, something like this: not sure if it would mount right or not. It does say use acorn lugs.
http://cgi.ebay.com/ebaymotors/CRAGA...QQcmdZViewItem
I'll have to see how large the holes are in the wheels though.
Old Jul 7, 2007 | 03:45 AM
restomod87's Avatar
restomod87
The shimmy you are feeling may be caused by unbalance of the rear wheels and tires... It has happened to my car previously and was due to hitting some railroad tracks at 40-50 mph and throwing my allignment off.
NorthAmericanTuning
Nov 9, 2016 11:45 AM
NorthAmericanTuning
Nov 9, 2016 11:44 AM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
jjwinel78
Aug 17, 2015 03:34 PM
mustangsrforever!!!
Aug 6, 2015 12:04 PM
