Identifing Windsor Engine
Old Jul 8, 2007 | 04:06 PM
gagne's Avatar
gagne
Default Identifing Windsor Engine
I need confirmation on what windsor engine I have. What I've concluded from my own research is that I have a pre '77 351 Windsor engine in my 1967 Mustang. I came to this conclusion after gathering the following information:
1) Valve cover has 6 bolts (so, not a 351 Cleveland).
2) The intake manifold has 8 bolts on each side (16 bolts total). This tells be that it's not a 221, 260, 290, 302 or a 77 or later 351W.
I also have installed on the car the following (previous owner installed these), but this did not help me much when trying to identify the engine block:
1) Edelbrock Carburetor 1406-0798 - numbers on the carb
2) Avtolite 124 spark plugs
So, did I identify the engine block correctly? I was unable to find the casting numbers, so I was unable to use that to determine the precise year. I know it should be close to the starter, but I can't find it. Would this be under something which is installed already?
Thanks!
Old Jul 8, 2007 | 04:46 PM
my77stang's Avatar
my77stang
Default RE: Identifing Windsor Engine
yeah, under the starter
Old Jul 9, 2007 | 01:02 PM
silverbullet69's Avatar
silverbullet69
If the heads are on the engine, 351 is stamped on the head in the rocker arm area.
Nick Oliver
Oct 17, 2018 04:22 AM
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
rksnow1
Sep 14, 2015 08:46 PM
TfcCDR
Sep 14, 2015 12:08 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
