new radiator, still hot?
Old Jul 8, 2007 | 07:55 PM
sixt5's Avatar
sixt5
Default new radiator, still hot?
i just bought a 2 core (1 inch) aluminum radiator from Northern, also a shroud/electric fan (14 inch 1550 cfm) combo that bolts directly to the radiator. It held pretty steady at 190 degrees while it was around 91 outside today. Is that a normal operating temperature?
also, can i adjust timing to lower the temperature? Which direction and how much?
Old Jul 8, 2007 | 08:20 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: new radiator, still hot?
ORIGINAL: sixt5
Hey Noob. These engines run their best at between 190 and 210 temp. You seem to have conquered the overheating problems that many mustangers are having or have had. As far as timing, keep it at 6-10 degrees BTDC depending on your altitude.
Old Jul 8, 2007 | 08:30 PM
sixt5's Avatar
sixt5
what lb cap are you running?
Old Jul 8, 2007 | 08:41 PM
Gun Jam's Avatar
Gun Jam
13 for me i think thats pretty common
Old Jul 8, 2007 | 08:48 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: Gun Jam
Yeah, I run 13 . Works for me.
Old Jul 8, 2007 | 09:07 PM
Aussie66Fastback's Avatar
Aussie66Fastback
have you installed a filter?
alum rads are difficult to impossible to clean out once blocked, so if you swapped out a conventional radiator for alum because it was clogged, you can destroy the new alum radiator in a matter of a few hundred miles.
worth protecting your investment
http://www.mako.com.au/auto/tefba.htm
Old Jul 8, 2007 | 09:17 PM
JamesW's Avatar
JamesW
If you have a 180 degree thermostat installed...I'd say that sound just about perfect.
Old Jul 8, 2007 | 09:23 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: JamesW
Ummmm. I wonder where you got that infromation from?
Old Jul 8, 2007 | 10:16 PM
urban_cowboy's Avatar
urban_cowboy
ORIGINAL: Aussie66Fastback
Tell me more about this filter. I am about to buy a new aluminum radiator and sure do not want it blocked in a few hundred miles! Is the filter heavy duty? It looks a little light weight. Does the screen corrode at all? Kinda seems like another point of failure, but if it works...could be handy.
Old Jul 8, 2007 | 10:25 PM
66GTKFB's Avatar
66GTKFB
Gano, NPD 2007 pg 76 $51.95.
Jim
