vibration when driven over 30 mph
Old Jul 9, 2007 | 12:22 PM
five pt oh's Avatar
five pt oh
Default RE: vibration when driven over 30 mph
if he recently had clutch work done, then they probably had to remove the drive shaft. When they did that, it's possible that they messed it, or the u-joint up while they were removing it or putting it back in if he wasn't careful.
Right now I'm picturing your car on a lift last monthwhere a guy accidently dropped your drive shaft about 6 ftonto the shop floor, leaving a nice little bow in it. Or it could have beensomeone beating on it prettyhard to get itout...which could have messed up your u-joint.
Old Jul 9, 2007 | 12:29 PM
67mustang302's Avatar
67mustang302
If it's ok under hard acceleration but vibrates everywhere else it's most likely the u-joint, I'd have that a lot before I got traction bars. My wheel hop was so bad that I'd go through a u-joint every 4 months even trying to be careful
Old Jul 9, 2007 | 12:56 PM
Soaring's Avatar
Soaring
I ♥ Acer
Take your drive shaft off and take it to a machine shop to have them check the balance and overall condition. Then assemble it with a new set of Universal Joints.
Old Jul 10, 2007 | 04:13 AM
gumballer's Avatar
gumballer
thanks lads i will check that they weekend when i get home. i wil let u know how i get on
Old Jul 10, 2007 | 12:17 PM
67mustang302
Soaring, here's one for you, the original Ford quality. I still have my factory driveshaft with the factory balance from 40 years ago, untouched. And there's no vibration at any speed(at least not that I can feel over the engine/exhaust)
Old Jul 17, 2007 | 08:01 AM
gumballer's Avatar
gumballer
i had a look at the uv joint, it looks pretty good. there is a small bit of movement but very little. could this still be the cause of it. another thing i noticed is that my brake lines are actually running across the drive and are hitting it, surely this is not safe.
Old Jul 17, 2007 | 11:00 AM
JMD's Avatar
JMD
ORIGINAL: gumballer
Even a small amount of play in a u-joint can cause vibration, and yes anything touching the driveline is not good, it will cut the driveline in time. I am assuming that it is the e-brake cables that are dragging on the driveshaft and not the hydraulic lines,,, either way it is not good....
It is also possible that the cables may have knocked the ballance weights off of the shaft, or otherwise unballanced the shaft.
4cylinderplus2
Oct 9, 2020 07:45 PM
baddog671
Jul 26, 2016 01:20 PM
TCStangerv6
Oct 11, 2015 05:57 PM
KingRando
Oct 2, 2015 08:06 AM
treesloth
Sep 28, 2015 07:03 AM
