sandblast cost?
Old Jan 16, 2005 | 04:10 PM
f8lpony's Avatar
f8lpony
Default sandblast cost?
i was wondering how much it would cost to have the engine compartment sandblasted in a 66 mustang, and could they do it without ruining the rest of my car? ANY BODYSHOP GUYS OUT THERE!
Old Jan 25, 2005 | 11:03 PM
gizahuna's Avatar
gizahuna
Default RE: sandblast cost?
I have a 68 coupe and I'm getting the body done. I priced a complete stripping of the paint, rust, and anything else on the body at $800 using a "sandblasting" method. Not sure on just the engine compartment. I only found one shop in my area (CT) that did this type of work. I did a google search for "dry stripping" in my state.
Hope this helps....good luck.
Old Jan 26, 2005 | 05:40 PM
Soaring's Avatar
Soaring
I ♥ Acer
oboviously, you will have to pull the engine to have the work done. At any rate, you can do it yourself if you can pull the engine and use a media blaster, or a second option of wire brushing and scraping.
Old Jan 26, 2005 | 10:55 PM
nate's Avatar
nate
if u have a sand pad and something that can get it going nicely, u can do it for about the cost of about 30 sand pads and a day or 2 of time. well worth it because you will pay a pretty penny probably for the sand blast option.
Old Jan 26, 2005 | 11:21 PM
tornado's Avatar
tornado
yeah u should try doing it urself ... youll save alot of money, especially if it's going to be a daily driver
Old Feb 7, 2005 | 08:38 PM
SgtCowan's Avatar
SgtCowan
If you do any sand blasting on your own do it outside. After I got my new compressor I wanted to try out a friends sand blaster and for some reason i did it inside (newb is the best reason I can think of, or giddy with excitement of my new compressor). It's been about 4 days and I still am sweeping/blowing/vacuming sand at night.
Old Feb 8, 2005 | 05:44 PM
69mach1377's Avatar
69mach1377
I heard that urea media is better than sand for blasting...
Old Feb 8, 2005 | 05:51 PM
horseshoeing's Avatar
horseshoeing
ORIGINAL: SgtCowan
[sm=roll.gif]When I think of doing that inside......What a mess. Everywhere. Not just on the ground, but everywhere.
Old Feb 8, 2005 | 06:22 PM
SgtCowan's Avatar
SgtCowan
Yeah I quickly put that in the lessons learned section. I won't ever even think about doing that again.
Old Feb 25, 2005 | 09:43 PM
SgtCowan's Avatar
SgtCowan
Bought a 40 LB sand blaster from harbor freight for 79 dollars to replace my old sand blaster and it works great. Just so you know U can get one and do it your self pretty cheap
