manual steering conversion
hello, i have a 66 coupe with power steering and im looking to convert to manual steering. my question is what exactly is involved with this conversion? do i need to replace everything between the tie rods, or do i just need a manual gear and remove the power valve? thanks for your help.
Why do you want to do this? The PO took the PS off my car and was manual when I bought it. I bought the car with the PS parts, and that was the first thing I put back on.
If you really want to change over, you take off the PS pump, PS ram and linkage, and PS valve. You then need to put on a manual linkage. I ended up with one linkage part when I finished converting back from manual to power. I do not have my diagrams infront of me, but I think it is the center drag link that you need for a manual steering car. I think everything else is the same.
I could be wrong, but I thought the pitman arm connected to the PS control valve which connects to the PS drag link. I thought you needed a manual steering center link to connect to the pitman arm. Correct me if I am wrong. I will take a look at my diagrams tonight to verify.
I converted mine from power to manual. Pull all the PS assembly out and either install a new manual centerlink or buy a "convertor piece", which is just a piece of steel to fill in the spot for the valve and connects the pitman arm...
ORIGINAL: 66GTKFB
Stick to your 69, on the real classic Mustangs, the control valve is part of the center link, aka, drag link. The power steering type costs about a hundred bucks more.
Jim
Jim
hey everyone, thanks for your info. but i got some more questions. how do i know if i have a short shaft or long shaft in my steering column? because its a part of the steering gear right? where can i find the lengths of both?
BeatnikFink
Oct 1, 2015 08:00 PM
