camshaft question
Old Jul 13, 2007 | 09:55 PM
Sean W.'s Avatar
Sean W.
Default camshaft question
Hey fellas,
Im buying a new camshaft and I have a couple questions
Is summit racing better than or equal to Edelbrock's camshafts
Also, there are a couple differences in the duration of the inlet/exhaust degreese, and i have questions. which would be the best for horse power? im looking at 2 different kits.
270/ 280, Lift .448/ .472 ( idel - 5500 RPM )
or
276/ 286, Lift .471/ .471 (1500- 4000 RPM )
im not going to be racing, just crusing... and gunning it at on ramps
Old Jul 13, 2007 | 10:37 PM
my77stang's Avatar
my77stang
Default RE: camshaft question
i had the summit cam your looking at, and with my stock ex manifolds going into a single pipe and weenie 4bbl intake from a 83gt it ran out of steam at about 5000-5500 but it would melt the tires and pull hard right up until the 5000+ mark. (and im pretty sure the flattening out after 5000+ was due to the intake and exhaust.
i'd have no qualms about getting another one for a streetable 302, it had a pretty good idle quality too.
note the summit has longer duration and more lift that the edelbrock yet the edelbrock lists its powerband higher - thats pretty much wrong - grab the summit for 79 bucks or whatever it is
Old Jul 14, 2007 | 12:49 AM
Sean W.'s Avatar
Sean W.
ORIGINAL: my77stang
is that good or bad?
Old Jul 14, 2007 | 12:58 AM
my77stang's Avatar
my77stang
good, that means the edelbrock cam is a weenie - cause its smaller than a cam that is still considered tame
btw it will work with stock springs but you *may* experience valve float at higher rpms (and if there are shims under your springs from a previous valve job they would bind)
Old Jul 14, 2007 | 02:23 PM
Sean W.'s Avatar
Sean W.
i dont know if this tells you anything, but i JUST got a valve job re-ground valves, freez plugs, new springs )... and i had the heads ported and polished...
Old Jul 14, 2007 | 02:25 PM
restomod66's Avatar
restomod66
Both Crane and competition cams make good camshafts also.
Old Jul 14, 2007 | 02:29 PM
Sean W.'s Avatar
Sean W.
yes, but they are more expensive...
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
NYstang
Sep 30, 2015 09:56 PM
