Ford 289 Header Bolt Size?
Old Jul 14, 2007 | 10:31 AM
Cargon's Avatar
Cargon
Default Ford 289 Header Bolt Size?
Does anyone know off the top of their head what the size and thread count are for the header bolts on a 1967 289?
Old Jul 14, 2007 | 10:34 AM
66GTKFB's Avatar
66GTKFB
Default RE: Ford 289 Header Bolt Size?
3/8-16 and all should be grade 5 or better.
Jim
Old Jul 14, 2007 | 10:39 AM
Cargon's Avatar
Cargon
thanks
Old Jul 14, 2007 | 12:29 PM
gothand's Avatar
gothand
Keep in mind that the bolt heads for headers have smaller heads than standard bolts out of the bin. You can usually find bolts designed for headers at your local auto parts store in the "speed section". Unfortunately, you may have to purchase two packs as the kits are often designed for Chevy small blocks which I believe only use six bolts per side.
Good luck!
Jeff
NorthAmericanTuning
Nov 9, 2016 11:45 AM
NorthAmericanTuning
Nov 9, 2016 11:44 AM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
Valkdriver
5.0L V8 Technical Discussions
Aug 13, 2015 08:57 AM
mustangsrforever!!!
Aug 6, 2015 12:04 PM
