Won't start when hot
Old Jul 16, 2007 | 11:33 AM
gothand's Avatar
gothand
Default RE: Won't start when hot
Next time you encounter this problem, remove the wire from the coil. If it then turns over freely, you've confirmed the timing is too far advanced and/or your starter is not strong enough to run an agressive initial advance.
Easy pie!
Old Jul 16, 2007 | 11:57 AM
67mustang302's Avatar
67mustang302
ORIGINAL: gothand
Easy pie!
That's a good idea, if the problem goes away it's ignition, if it persists it's starter(or possibly electrical).
Old Jul 16, 2007 | 12:05 PM
RobbieG.'s Avatar
RobbieG.
ORIGINAL: 67mustang302
ORIGINAL: gothand
Easy pie!
I have never heard of this before. Very good idea!!! Makes sence too. Thanks.
Old Jul 16, 2007 | 05:31 PM
dcohen's Avatar
dcohen
possibly vaporlocking?
Old Jul 16, 2007 | 05:36 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: dcohen
That's why I said to have a phenolic spacer under the carb and to make sure the fuel lines are away from the engine heat. Timing should be between 6 and 10 degrees BTDC. Mine runs great at 10 degrees using 87 octane and runs cool as a cucumber.
Old Jul 16, 2007 | 05:47 PM
brooksamz's Avatar
brooksamz
Had same trouble with another vehicle I had....Starter gets overheated...had to start vehicle with a crow bar accross the solenoid. Works ever time!!
Old Jul 16, 2007 | 06:01 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: brooksamz
Using a crowbar or a screwdriver to connect the positive points on the solenoid (starter relay) has noting to do with a hot starter. If that works for you, then you need to go upstream to the starter switch itself.
Old Jul 16, 2007 | 06:09 PM
Derf00's Avatar
Derf00
Gentleman's Relish
ORIGINAL: St3mpy
Today wasmy first real drive in the mustang, and it drove ok,but when I stopped to get gas, I couldn't get it to start back. It acted like it was a dead battery, but after waiting about 20 min, iot cranked again (I did have jumper cables attached to it though). Once I got to my destination, after I turned it off, I checked to see if it would start again, and it woulnd't. Again, it sounded as if the battery was low, the engine was barley turning over. When I came back about 10 min later, it sounded better, but still wouldn't start, and then about 2 hours later, it started just fine. My car does have long headers. Could they be overheating my starter?
Yes you are heat soaking your starter. I would recommend either wrapping our headers or putting a heatshield on your starter. Should take are of your problem.
Old Jul 16, 2007 | 06:12 PM
Derf00's Avatar
Derf00
Gentleman's Relish
ORIGINAL: dcohen
That would be true if it turned over, and just didn't catch. I read that it would not turn over at all, or very slowly. That has nothing to do with vapor lock.
Old Jul 16, 2007 | 08:00 PM
xswoopr's Avatar
xswoopr
I once had this same problem with a recently rebuiltengine that ran too hot, it was like it almost seized whenever I shut it down. The bad news is that it did eventually overheat and seize. My mechanic friend beleived that the pistons (rings) were too big for the bore which caused too much friction and unusually high compression. This would be an obvious machining error.Has yours been rebuilt recently? If so check the compression. When you start up does it warm up quicker than normal? When you shut it off does it wind down a bit or stop abruptly as soon as you turn the key?
I hope that your problem is less severe than mine was. Good Luck!
