Golden Hack Award Nominee
Old Jul 16, 2007 | 10:33 AM
1965 HT Owner's Avatar
1965 HT Owner
Default Golden Hack Award Nominee
So I started pulling the front fenders and doors yesterday and came upon this hack on the lower section of the driver side front fender. It is a cocktail of bondo, fiberglass mesh, and spray foam as a patch job on the lower section of the fender. Not sure if I should just cut off everything below the crease and weld in a patch or just hunt for a new fender. Can you buy a fender patch panels?
Big chunk of crap!
Big chunk of crap turned over.
Inside view of upside down fender showing the mess.
Old Jul 16, 2007 | 10:42 AM
JMD's Avatar
JMD
Default RE: Golden Hack Award Nominee
Just what was the PO trying to acomplish with this mess? Were there holes under that mess?
If it were me I would be very tempted to replace the whole fender.........
Old Jul 16, 2007 | 10:48 AM
1965 HT Owner
I have no idea what they were thinking. What is the name of the vertical brace that is attached to the fender? I assume a new fender doesn't come with that piece?
Old Jul 16, 2007 | 11:33 AM
66GTKFB's Avatar
66GTKFB
That's part of the fender, look at the other side too. Get a used one.
Jim
Old Jul 16, 2007 | 11:41 AM
Soaring's Avatar
Soaring
I ♥ Acer
Depending on your welding skills, you can either patch it or get a new fender.
Old Jul 16, 2007 | 11:45 AM
JMD's Avatar
JMD
ORIGINAL: JMD
Duh,,, yea I see the hole now, it kind of blended into the background, I thought that the concrete showing through the hole was metal,,,,
A considering the cost of replacements these days, areplacement is in order IMO..
Old Jul 16, 2007 | 12:02 PM
boogerschnot's Avatar
boogerschnot
I would just replace it,, Its not worth the time to patch,, If it were the rear quarter then I would patch, but its just too easy to slap a fresh, new front fender on, and no worries about it later.
Old Jul 16, 2007 | 12:11 PM
1965 HT Owner
After looking at the National Parts Depot catalog, it looks like there are 2 choices for fenders (repro or OE). Quite a bit of difference in price at $129 compared to $324. []
65-66 RH, OE Ford tooling, 21ga .........16005-1 324.95
65-66 RH, repro, improved design, 21ga
.................................................. 16005-1C 129.95
65-66 LH, OE Ford tooling, 21ga .........16006-1 324.95
65-66 LH, repro, improved design, 21ga
.................................................. 16006-1C 129.95
Old Jul 16, 2007 | 12:18 PM
Soaring's Avatar
Soaring
I ♥ Acer
I'd get the Ford tooling.
Old Jul 16, 2007 | 12:26 PM
EmperorOfChicken's Avatar
EmperorOfChicken
soaring you jacked my sig anim!!![8D]
