WEIRD CLUTCH ISSUES
Old Jul 17, 2007 | 02:58 PM
onegreedy's Avatar
onegreedy
Default WEIRD CLUTCH ISSUES
OK SINCE GETTING THE 67 last week i have been driving it every day,
now i went to pick up my 94 honda and when i got in it and pushed the clutch in the first thing that went thru my mind was what the hell the clutch is broken, but then after pumping it i realized its just not as stiff as the mustang clutch with the z bar,
sooooo now i want a softer clutch for the mustang , what is better cable or hydraulic and whats an easy swap
i am running 351 w with t5 using the 4 spd bell housing and adapter plate
i can go to a standard to bell housing if i get the cable or hydraulic
thanks
Old Jul 17, 2007 | 03:03 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: WEIRD CLUTCH ISSUES
I have cable in my 03 Mach and my clutch pedal is stffer than......well, you get the point. My 65 is much softer. Based on mine, I wouldn't go cable. Maybe hydraulic if that is a possibility.
Old Jul 17, 2007 | 03:38 PM
67SuperSnake's Avatar
67SuperSnake
My hydraulic is very stiff. But I have a dual Ram clutch, so I cannot really help.
Old Jul 17, 2007 | 03:47 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: 67SuperSnake
I'm in that same situation with my beefed up clutch too. My nephew had me put something cabe-wise on his 02 GT that relieved the pressure of the clutch being so tight. I can't remember the name of it, but it did work. He can adjust the pressure from the engine firewall side.
Old Jul 17, 2007 | 04:20 PM
onegreedy's Avatar
onegreedy
gonna try to replace all bushings, then lube everything elseb and see if i can get a softer return spring
Old Jul 17, 2007 | 04:27 PM
Soaring's Avatar
Soaring
I ♥ Acer
Actually the spring under the dash that is attached to the clutch pedal is the one that helps you soften the pedal push.
Old Jul 17, 2007 | 05:23 PM
67SuperSnake
One other thing you can do:
Old Jul 17, 2007 | 05:42 PM
JMD's Avatar
JMD
ORIGINAL: Soaring
did you ever get those new rear end gears in for your nephew??
Old Jul 17, 2007 | 05:44 PM
JMD's Avatar
JMD
That is a nice looking kit,,, Mustang Steve?
Old Jul 17, 2007 | 05:48 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: JMD
ORIGINAL: Soaring
Nah, I told him to return those 410s and get his money back. He already has the 323's which is enough for his teenage ***.
