Front Disk Brake Conversion
Old Jul 23, 2007 | 01:04 PM
66pony21's Avatar
66pony21
Default Front Disk Brake Conversion
I found a full front disk break kit for sale from a guy across town. He wants only a $100 for everything, the only problem is that it is off a 67 Ranchero will that fit on my 66 coupe?
Old Jul 23, 2007 | 01:51 PM
66GTKFB's Avatar
66GTKFB
Default RE: Front Disk Brake Conversion
It may, if it's a four puck caliper type. At that price, I wouuld not be surprised if you need the calipers rebuiltand will need new rotors and hoses. That's about $400 to $500. However, the attaching brackets and proportioning valve may make it worthwhile.
Jim
Old Jul 23, 2007 | 03:48 PM
66pony21's Avatar
66pony21
How can I tell if it is a four puck caliper?
Old Jul 23, 2007 | 03:53 PM
66GTKFB's Avatar
66GTKFB
The caliper has four pistons, two on each side as opposed to the floating caliper that has one. Look at NPD http://www.npdlink.com/under p/n 2B120-2B for the four piston type and p/n 2B120-3A for a single.
Jim
Old Jul 23, 2007 | 03:57 PM
66pony21's Avatar
66pony21
It just has the one caliper. Do you think it is still worth it?
Old Jul 23, 2007 | 04:02 PM
fastbackford351's Avatar
fastbackford351
Foghorn Leghorn
It's hard to go backwards on a set of disc brakes for 100.00. You could sell them on ebay for more than that.
Old Jul 23, 2007 | 04:08 PM
66GTKFB's Avatar
66GTKFB
It won't fit and if it's rusty, it won't sell. If you don't wheel and deal on e-bay - pass.
Jim
Old Jul 23, 2007 | 05:28 PM
quinchem's Avatar
quinchem
Here is a link to a conversion kit I think is reasonably priced and is a grenada basis. I ordered it with the "power brake upgrade" which includes the new brake pedal and booster etc. The kit shown is $545 and the upgrade is $250 or 275. With upgrade and delivery it was still under $900. It should be here tomorrow!
http://discbrakeswap.com/
Old Jul 24, 2007 | 09:30 PM
mikethebike's Avatar
mikethebike
ORIGINAL: 66GTKFB
Jim
If it is a 4-piston caliper with the mounting bracket that bolts to the spindle why would it not fit? Is the bolt spacing on a 4-piston Fairlane bracket different from a Mustang? If the bracket will mount to the spindle the only other problem would seem to be bearings and seals and so long as you have the inside and outside measurements that wouldn't be difficult to overcome.
Old Jul 24, 2007 | 11:59 PM
66GTKFB's Avatar
66GTKFB
For the simple reason of - it's a single piston type. Go to post # 5 and read.
Jim
