Motor install question
Old Jul 23, 2007 | 04:09 PM
quinchem's Avatar
quinchem
Default Motor install question
I'll be intalling my motor later this week and am wondering if I can/should install it with the tranny attached? I borrowed a hoist to pull the 6cyl out. I had trouble as I didn't know where to attach the hoist, plus I tried to pull it with the tranny attached so I attached the hoist at the front of the motor and it came outupright and I had to stop half way to pull thetranny off. I pulled the 289 out of the junker with a bobcat and have never intalled a V8 (done a million vw's!). Is/arethere any tricks or tips that will make life easier?? Thanx
Old Jul 23, 2007 | 04:14 PM
gothand's Avatar
gothand
Default RE: Motor install question
I always install the engine and tranny together as a unit ... especially when I had a toploader which is much heavier than the T5.
You'll want to use a load leveller for the hoist so that you can angle the engine just right. If you don't have one, they can be had for about $40 from many auto parts stores. Also, drop the drag link from the passenger frame railso the bellhousing doesn't get caught up on it. Make sure you have a helper to help watch the back side and guide it in so you don't scratch up the firewall or radiator support.
Good luck!
Jeff
Old Jul 23, 2007 | 05:15 PM
quinchem's Avatar
quinchem
Thanx! I have a leveler with the hoist. Where shoiuld I attach the chain?
Old Jul 23, 2007 | 05:26 PM
jcomp's Avatar
jcomp
Go slow and don't let it swing around too much. Don't put your fingers under it.
I like to have someone else around just in case. Have a pipe (handle for the hoist works well) handy in case you need to pry the assembly around a little.
I've always attached the 4 points of the leveler to the four outer intake manifold bolts if I could. I also use bolts that are a little longer and make sure they have good engagement.
I think doing the engine/trans as an assembly is usually the best.
It's not really a big deal, you'll be fine as long as you don't put your fingers under it.
Old Jul 23, 2007 | 05:58 PM
gothand's Avatar
gothand
With a 4-chain leveler, I have always connected it to the accessory bolt holes on the heads. Make sure the bolts are thoroughly engaged and you should have no problem.
Old Jul 24, 2007 | 01:39 AM
IM RICKY BOBBY's Avatar
IM RICKY BOBBY
+1 for bolting the leveler to the bolt hole on the heads.
+1 for dropping the engine while the tranny is connected
sometime once the engine is down the motor mount holes dont always alighn perfectly, ill grab a big screw driver or something like that and stick it in the hole and move it around to alighn the holes correctly...
good luck
Old Jul 24, 2007 | 02:18 AM
Aussie66Fastback's Avatar
Aussie66Fastback
ORIGINAL: IM RICKY BOBBY
is that why jcomp says dont put your fingers under it
Granatelli Sales
Dec 18, 2015 06:22 PM
Hogquad
Aug 23, 2015 05:26 AM
classic69FB
Aug 12, 2015 11:58 PM
$A_Money$81
Aug 11, 2015 01:30 PM
