250 intake?
Am i just not looking hard enough or does no one offer a intake manifold for a 250? Ive tried looking at mustangs unlimited and NPD..and i cant find any intake for my 250 help???????/!!!!!Thanks
RE: 250 intake?
What kind of intake?
Jim |
RE: 250 intake?
A 2v aftermarket intake manifold.
RE: 250 intake?
Go to the FAQ portion of this forum andgo down to section XVI which is dedicated to six cylinder engines.
Jim |
RE: 250 intake?
Still cant find any parts just forums with no one answering?
RE: 250 intake?
RE: 250 intake?
The intake manifold for all american 140, 170, 200, and 250 cubic inch engines is casted onto the cylinder head. To get a 2 barrel on there you can:
1. Install a carb adapter, you can find one at www.classicinlines.com 2. Take your head to a machine shop and have them cut of the 1 bbl carb pad and weld on a 2 bbl pad. (you could even have the entire intake log milled off and a customflange welded on with an intake manifold made up.) 3. Find yourself a cylinder head from Australia or Argentina. They have removable manifolds from the factory. 4. Buy the new aluminum cylinder head that is coming out from www.classicinlines.com In any case, no matter what you do, you should visit www.fordsix.com and ask your questions there. |
RE: 250 intake?
ORIGINAL: mustube The intake manifold for all american 140, 170, 200, and 250 cubic inch engines is casted onto the cylinder head. To get a 2 barrel on there you can: 1. Install a carb adapter, you can find one at www.classicinlines.com 2. Take your head to a machine shop and have them cut of the 1 bbl carb pad and weld on a 2 bbl pad. (you could even have the entire intake log milled off and a customflange welded on with an intake manifold made up.) 3. Find yourself a cylinder head from Australia or Argentina. They have removable manifolds from the factory. 4. Buy the new aluminum cylinder head that is coming out from www.classicinlines.com In any case, no matter what you do, you should visit www.fordsix.com and ask your questions there. |
