High oil pressure ... troubleshooting tips?
Old Jul 24, 2007 | 12:38 PM
scuf23's Avatar
scuf23
Default High oil pressure ... troubleshooting tips?
Well, my pressure gauge indicated that my oil pressure was high ... when I stopped, I noticed that I had been leaking some oil ... any recommendation in terms of how to find why this happened?
My temp is good, the oil and oil filter were changed less than 350 miles ago
Thanks!
Old Jul 24, 2007 | 01:26 PM
JMD's Avatar
JMD
Default RE: High oil pressure ... troubleshooting tips?
ORIGINAL: scuf23
Thanks!
The only thing that would cause high oil pressure would be a stuck or defective presure relief valve in the oil pump itself.
Verify that the pressure is high by substituting a mechanical guage in the place of the oil sender. You can use a (new) grease hose for a grease gun to hook the guage up.
Old Jul 24, 2007 | 02:20 PM
scuf23's Avatar
scuf23
What about a stuck PCV? could that cause the oilpressure to increase?
Old Jul 24, 2007 | 02:21 PM
jlg2002's Avatar
jlg2002
ORIGINAL: JMD
ORIGINAL: scuf23
Thanks!
Yea, I was going to say the same about it could be the gauge. What are you considering high oil pressure? sometimes thicker oil (high weightnumber) will cause the pressure to go up. Does the oil pressure go up significantly with engine rpm? that would really show a stuck PRV in the pump. a little Berryman "Chemtool" or Justice Brothers "Engine Tune Up" in the oil and let it run for a 1/2 hour or so may unstick it if its a sticking PRV, but change the oil afterwards if you use the Berryman.
jlg2002's Avatar
jlg2002
nope to the PCV.
Old Jul 24, 2007 | 02:31 PM
JMD's Avatar
JMD
ORIGINAL: jlg2002
nope to the PCV.
+1.... due to how the oil system is set up, there are only 3 possible reasons for a high reading oil pressure guage....
1. Guage, sender, or wiring is defective.
2. The oil is way too thick, this time of year it would have to be like 80 wt gear oil or somthing
3. The pressure relief valve in the pump is not working.
The first two possibilities can be eliminated without much work,,,,,
Old Jul 24, 2007 | 02:43 PM
scuf23's Avatar
scuf23
ok - Thanks guys - I'll get on it and hopefully resolve the issue
Old Jul 24, 2007 | 02:44 PM
jlg2002's Avatar
jlg2002
Agreed about the thick oil, but it really makes difference as to what"high" means. I've seen the needle get higher by going from 5w20 to 10-40 or single weight oil.
Sep 17, 2015 07:57 PM
Scottyboy187
SVT Forums
Sep 13, 2015 10:23 PM
Sep 10, 2015 08:39 PM
Sep 8, 2015 11:50 AM
