302 fine tuning failures
Old Jul 25, 2007 | 02:18 PM
Pheildy's Avatar
Pheildy
Default 302 fine tuning failures
What i have: 73 mustang
No a/cor power brakes.Only have powersteering.
Soon to have dual exhaust
302 rebuilt w/ 289 heads completly ported
mild "Comp" cam
Edelbrock: AirGap intake& 650 cfm w/ sec. vacuum
Msd blaster2 coil.
C4 trans. rebuilt with a shiftkit and a 2400 stall conv.
I have removed all smog application and everything else is stock. Im not sure how much the stock Dist. and points have to do with my troubles but i have the timing and dwell perfectly at stock and there is still hesitation (probably carb). S/P gaps are stock. I have vacuum advance and vacuum from my trans. Both hooked up to a 'T' then to my carb.
My transmission used to have a dual port vacuum switch on it but the guy who rebuilt it said i would only need a single one going to carb/vacuum if i was taking my smog out. --?-- not sure if he was right.
I want to get an MSD dist. with hei to finally be rid of points.
Am i on the right path with all this? I'm not sure how much the tuning specs need to change (if any) and/or what i need to setup my carb with (jets, springs, etc) because my carb is stock also.
|I am also interested in mod'ing this stang to have a shaker hood assembly
Old Jul 25, 2007 | 03:08 PM
quinchem's Avatar
quinchem
Default RE: 302 fine tuning failures
Not sure on the rest of your questions but you can save a bunch by going with "petronix"(...I think I spelled it right) ditributor upgrade. It bolts up to your existing distributor. It's about 1/2 the cost of the whole distributor, and you just take out your points and cond, pull the 2 wires through,and screw this thing to the same holes...gap it and you're done. There is a part that fits under the rotor and that's all the parts the kit comes with. You should re-gap the plugs to .042 also.
Old Jul 25, 2007 | 05:26 PM
67mustang302's Avatar
67mustang302
What exactly does the car do when it hesitates? And what cam do you have and how much head work? The RPM Air Gap and a 650 are pretty big induction for a street302 unless it has large heads and a large cam(and I mean large)
Old Jul 25, 2007 | 05:38 PM
Soaring's Avatar
Soaring
I ♥ Acer
Your stock system needs nothing more than a Pertonix electronic system. Google it.
Old Jul 25, 2007 | 11:20 PM
Colorado_Mustang's Avatar
Colorado_Mustang
The Edelbrock carb may be limiting your adjustment possibilities, but try to richen the accelerator pump (I believe there are 3 holes to choose from...but it's beenwhile since I've worked on an Edel carb).
I don't know what you mean by 'mild' cam, though. A .500" lift cam would take full advantage of the air gap and carb, and that's mild in my book.
Also, make sure your distributor is connected to a timed vacuum port and not to constant vacuum. There is a port on the front of the Edel carb just for the dizzy.
Old Jul 25, 2007 | 11:25 PM
Pheildy's Avatar
Pheildy
i have heard of pertronix but dont mind spending the extra $ for the msd. Unless it could do damage then of course i wouldnt want to.
The hesitation is at low rpm'sAND when i go more than half-throttle.
Im almost positive the vacuum advance is off and my timing is at 6 btdc.
I just realized the vacuum line from my trans. was corroded and cracked. Big leak.
|As for my 650 carb and intake... if it was too much couldnt i bring the carb down?
I cant remember the lift's exactly on my cam but i know they were mild. More than stock lift ratio but not by much. And the heads were 168 out and 192 in ... might be off by a few but the valves were ported as far as they could be safely
Nick Oliver
Oct 17, 2018 04:22 AM
Sep 8, 2015 06:25 PM
Emblazoned
Sep 3, 2015 10:45 PM
whatsup62
Sep 3, 2015 01:38 PM
Sep 1, 2015 08:16 PM
